Air Rifle advice requested - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 53 of 53
  1. #41
    Dec 2008
    Vt USA
    6,800
    748
    2356
    Quote Originally Posted by MJPfin View Post
    Yes it's subjective but I'm talking about power levels over 700fpe trying to make that on a regulated gun is pretty difficult.
    And here in Finland we are not allowed to hunt with airguns so my shoot Ng is mostly from bench to 100-300m tethered to a bottle with a bottle regulator.
    Marko
    700fpe? That's 220 grains at 1200fps. Big bore for sure! Not .25 cal...'-)
  2. #42
    Apr 2017
    FINLAND
    199
    36
    52
    Yes its .457 but my real bigbore is 20mm made from Madsen autocannon barrel, we managed to achieve unofficial air rifle power record of 3150fpe, 2160grain lead projectile at 810fps. And no the weight is not a typo it was 140 grams of lead.
    Marko
  3. Likes Hbjj liked this post
  4. #43
    Mar 2012
    Geilenkirchen, Germany
    2,410
    1447
    1222
    Well I use mostly Lothar Walther barrel blanks, Timney triggers and Boyds gun stocks.
    Rest of the rifle is barstock and 4130 tubing.
    Valves receivers, barrel work, chambering, stock inleting I do myself.
    Marko
    Thanks.......good tips, but where in hell do you find 4130 in Europe? I assume you import it from the USA.
  5. #44
    Apr 2017
    FINLAND
    199
    36
    52
    Aircraft materials sellers usually stock 4130 tubing.
    Marko
  6. #45
    May 2012
    Tennessee
    32
    50
    14
    Any of the HW rifles are excellent. The HW97 is a very nice rifle and would a excellent choice. It is a little on the heavy side, but if that doesn't bother you it's very accurate and one of the best quality production rifles made today. Flip a coin for what caliber you get. It's more a matter of preference, than one being better than the other. I prefer 22cal
  7. #46
    Mar 2012
    2,410
    1447
    1222
    This is a follow up to this saga. I did want to buy the Kral Super Jumbo in 5.5, but several things got in the way of that. First, I could not find any dealer in Holland or Belgium that had the 2018 model nor did they know when they would get them. I tried calling distributors and the factory in Turkey.......no joy. I then started looking at regulators, barrels and control valves and the effort to put it all together quickly realizing that this could be a real bag of worms with a potentially dubious outcome. If one could put a price tag on the parts, effort and aggravation, it started to make sense to buy what you want in the first place and it would not be more expensive. So I elected to change my mind and buy an FX Crown. They are the cat's meow. Everything I was looking for and more assembled, finished and tuned at the factory in Sweden. It certainly was not cheap. I got one in 25 cal. This thing shoots dime groups at 50 meters out of the box. I'm very happy with it. I picked up a Discovery 4.5-18 scope for it with a Mil dot reticle and it works perfectly with very clear bright optical glass. Highly recommended. This is truly an amazing air rifle. I guess it's like the old proverb says, you get what you pay for. I will comment on my progress with this once I have some time with it under my belt.
  8. #47
    May 2014
    Montana
    311
    229
    185
    What grain projectile and what velocity with that .25 caliber?
  9. #48
    Mar 2012
    2,410
    1447
    1222
    Quote Originally Posted by JLarsson View Post
    I'm currently using the JSB King 25 grain pellet. I'm not sure on the factory velocity, as I don't have my chronograph yet. When I do, I'll get back to you with the number. I have made no adjustments with anything. It is still factory set. The current setting of the regulator is 130 bar. I am estimating around 880 Ft/sec. The barrel is the new 60 cm long "X" barrel, where the rifling is rolled in externally. The bore is ultra smooth. The factory stated that the tune and barrel twist was optimized using the JSB King 25 grain pellet, which is advertised as having a .0360 BC.
  10. #49
    Mar 2013
    Washington
    289
    138
    199
    Marko
    Would love to see a pic or video of that
    And would you elaborate on the design at all ie the valve
  11. #50
    Mar 2012
    2,410
    1447
    1222
    Further follow up. I received my crono and measured at full hammer spring power, 940ft/sec with the regulator set for 120 bar. With the hammer spring set to minimum, the crono reads 640 ft/sec. This thing shoots nickel groups at 35 meters.........amazing. I'm reluctant to mess with the regulator. It works pretty good right from the factory.
  12. Likes JLarsson liked this post
  13. #51
    May 2014
    Montana
    311
    229
    185
    Sounds like a winner!
  14. #52
    Aug 2012
    California, Central Coast
    3,800
    2199
    1498
    Quote Originally Posted by steve-l View Post
    Further follow up. This thing shoots nickel groups at 35 meters
    Did you wear it out already?
    It seems to be loosing accuracy
    Seriously though it sounds like a really nice set up you have.
  15. #53
    Apr 2017
    FINLAND
    199
    36
    52
    Quote Originally Posted by Hbjj View Post
    Sorry for the late reply.
    Well the valve is of balanced design, there is internal balancer piston and cylinder to help valve opening and closing.
    Small video of shooting some saboted ..50 cal 620gr projectiles at around 3500J muzzle energy.
    Fury 2mm airgun shooting supersonic - YouTube
    Marko
  16. Likes Hbjj liked this post
