Alignment Pin Removal on Lyman Bullet Molds
Likes Likes:  0
Results 1 to 4 of 4
    Oct 2001
    Lewes, DE.
    1,419
    Hi There,
    Can someone tell me if the alignment pins on Lyman bullet molds are pressed in or threaded in?
    Thanks in advanced!
    Webb
    Feb 2004
    Redlands, Ca
    277
    ........Pressed.
    Best,
    Rick
    Jul 2003
    Linwood, Ma USA, the center of the known universe
    274
    There was an ealier thread on this subject but I don't remember which bbs. They are pressed, if removing try not to use a steel punch as you could mushroom the end and cause alignment problems.
    Paul G
    Dec 2003
    Calgary, Alberta, Canada
    1,419
    8
    97
    Use ana arbor press and a proper size punch preferably mounted to the ram of the press.
