Aluminium question
Results 1 to 8 of 8
    Aug 2018
    UNITED KINGDOM
    Default Aluminium question
    I am drawing up plans for an ultra lightweight bolt action rifle and have the idea of an aluminium bolt body with a steel insert bolt head with locking lugs, however I don't know if an aluminium bolt running in an aluminium receiver with work, will it wear badly or even gall up and stick ?
    Jan 2006
    470
    44
    Just go ahead and make the bolt all steel. You need a steel bolt head and also a steel extraction cam on the back end.
    Since the bolt is essentially a hollow tube, the weight penalty of an all steel bolt is not that great. Besides, you can use a commercial bolt like a Rem 700 and save a lot of money and time. The handle knob and bolt sleeve can be aluminum and are standard after market parts. Steel on aluminum is OK, aluminum on aluminum is not from a wear/friction perspective.
    RWO
    Dec 2013
    montana
    308
    32
    80
    why reinvent the wheel? kelblys panda actions are alum and very nice parts.
  4. Likes spitfire_er liked this post
    Feb 2006
    so cal, usa
    581
    201
    141
    Make the bolt out of aluminum if that's what you want. Hard annodize it and you should be OK
  6. Likes MIBill, Butch Lambert liked this post
  7. #5
    Oct 2004
    Montana
    1,068
    47
    45
    Check out Kimber Montana with kevlar stock and NULA rifles.
    Steel actions with light weight stocks.
    Hal
  8. #6
    Sep 2003
    Pacific NW
    673
    59
    Quote Originally Posted by Waterworks View Post
    Ignoring all the irrelevant advise, yes it will wear and gall unless coated or hard anodized.
    Since the bolt handle usually acts as the extraction cam, you will need a steel insert or such where it contacts the reciever.
  9. #7
    Nov 2004
    RC, CA
    1,967
    211
    371
    7075 and hardcoat ought to be good for a couple hundred cycles. It's a hunting rifle, right?
  10. #8
    Oct 2002
    Poetry Texas USA
    1,755
    314
    213
    Nothing wrong at all with an aluminum bolt. I believe I have a couple. Thrust acts on the steel bolt head not the bolt body. A hard coating will help any wear problem.
    Kelblys make aluminum receivers, but not aluminum bolts.
