I'm looking at a chamber chop job
to repurpose a Mauser 7.65arg barrel onto a AR 300 Blackout (303blackout) ...No-Gas Repeating Rifle SideCharger
By the time I remove everything south of the 7.65 Neck, there will just 14-18mm of full inch shank left to turn for AR 13/16 Barrel Extension threads. Past that, barrel profile has a immediate shoulder to 3/4".
Seems simple part-off at where the existing 7.65arg chamber shoulder starts,
face down to the start of the neck,
cut extension threads, ream & headspace new chamber like a regular barrel blank for AR.
Sanity Check please:
223 / 300Blk will be ok with a chamber just .75" od past the Extension (+ few mm tighten face),
since AR 13/16 threads minor dia leaves just .75" undisturbed as well?
Casual observation makes one believe the 3/4" (minor) under the extension implies a 3/4" od chamber would work. Casual can get you blownt up when gunsmithing, so I better check with others before proceeding
