AR15 Barrel dimensions, barrel extension? - Page 2
Likes Likes:  0
Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 68
  1. #21
    Sep 2007
    Michigan
    51
    Default Barrel extensions
    I am also looking for extension prints. Especially material, tolerance, heat treat, etc. Everyone I talked with is 12+ weeks out on orders. Looks like it might be reverse engineering time.....
  2. #22
    Dec 2006
    Council Bluffs, Iowa
    5
    Default Barrel extension drawing
    I have a pdf drawing of the barrel extension and would be glad to email you a copy.
    It is to large to upload so let me know if you still need it.
    I just checked with White Oak Armament and they have Barrel Extensions in stock.
    www.whiteoakarmament.com 1-309-376-2288
    Jim C
  3. #23
    Sep 2007
    Michigan
    51
    Thanks Jim,
    I just got 10 pcs in the other day and I took measurements off a couple that I had. Thanks for the suggestion on WOA. It would be interesting to see if your drawing is close to my measurements tho if you wouldn't mind. I've got mine drawn in .dwg or .dfx if anyone is interested send me a pm.
  4. #24
    Sep 2006
    northern arizona
    101
    Just an idea . You might try Bushmasters or DPMS . I think both supply parts to Brownells' .
  5. #25
    Apr 2008
    Northern VA
    318
    PM sent to HMC710 for a copy of the .dwg files. Thanks.
  6. #26
    Jan 2007
    Canada
    31
    Anyone have the specs for the chamfer into the chamber? Can't find it anywhere.
  7. #27
    Sep 2007
    Michigan
    51
    Default Chamfer
    I don't know what the 'factory' spec is, but I set my tool at 75 deg and put a .060" wide chamfer.
  8. #28
    Jan 2007
    Canada
    31
    Thanks guys.
  9. #29
    Apr 2009
    Minnesota
    77
    15
    27
    Heres a M4 profile:
    http://www.ar15barrels.com/tech/colt-m4.jpg
    Look in this directory, I thought I found a 9mm barrel profile in there.
    Jon
  10. #30
    Apr 2005
    North Bay, Canada
    36
    The M4 drawing shows the shoulder that the gas block butts up against as being 6.75" from the front of the barrel extension.
    On AR15barrels he shows the distance from the same shoulder to the breech as being 7".
    I think there is more than .25" from the breech to the front of the barrel extension?
    Does anyone know which is correct?
  11. #31
    Sep 2007
    Michigan
    51
    Default Extension barrel thread
    This is the method I use. Please verify your operation with your standards to ensure your safety.
    The breach of the barrel is turned to a dia of 1".
    The thread section for the extention is turned to a diamter of .805" to a lenghth of .624".
    The thread is then cut at 16 tpi.
    The extension is threaded on and torqued in place. I do not have the value handy so verify this, but I think it is in the 30-40 ft lbs range. Please verify for yourself.
    The bolt is then checked for fit and function. I hand fit bolts so they just drag on the engagement and are not loose while engaged.
    To adjust engagement either take more at the shoulder or more at the breach.
    The barrel is then ready for chambering.
    WARNING: Do not use this measurement to accurately and safely install an extension.
    Using a depth gauge I get approximately .500" from the end of the extension to the base of the barrel breach end.
  12. #32
    Apr 2005
    North Bay, Canada
    36
    Quote Originally Posted by HMC710 View Post
    Thanks. I got it all threaded and chambered. I just need to torque the extension and pin it.
    The measurement I was looking for was the distance from the front edge of the barrel extension to the back edge of the FSB/gas block (all of the above was still usefull!!). I used the one on the M4 barrel blueprint and it worked fine. Handguards are VERY tight. I used 6.75". I think another 10-20 thou wouldn't hurt.
    All I have left is to drill the gas port, torque the extension and pin it. I am assuming from the length of the pin that I will have to drill first. Is there a common number that anyone uses or should I just measure in each different case?
    Hopefully I will have it out to the range by next weekend to try it out.
  13. #33
    Sep 2007
    Michigan
    51
    Default Barrels
    www.ar15.com is a great resource. This is a link to specific torque values: http://www.ar15.com/forums/topic.html?b=3&f=4&t=315921
    Good job on chambering, just make sure you test function with a dummy round after you get the extenion on that the round will chamber and extract manually. As far as the extension pin, I have seen them range from installed high to low on other barrels. Its not very long so it doesn't take much of a pilot hole to sink it into the extension threads. Remember you want to accomplish two things with the pin; 1. Secure the extension. and 2; Index the barrel. Too low a pin will allow the barrel to become mis-aligned in the receiver.
    I do not know if the "factory" drills a pilot hole or not or just presses the pin in and lets it deform the threads, helping to lock the extension in place. I would guess this. I do know that a .050" deep pilot hole really sinks the pin in.
    As to your original question, I took it as "from the breech to the front of the extension"
    The gas block location can vary, to a degree. A 1/4", on a 5.56, is not going to make or break it. If you study the operation of the AR type of gas impingement system, you will be amazed at its complex simplicity. As they say, "timing is everything". Have you measured a factory barrel? I am looking for my barrel port size/location file and will link it when I get it.
    Brl Length (in) Brl Dia (in) Distance from Muzzle (in) Min Port Size (in) Max Port Size (in)
    11.5 .625 3.850 .081 .089
    11.5 .750 3.850 .086 .094
    14.5 .625 8.375 .063 .078
    14.5 .750 8.375 .070 .086
    16 .625 8.375 .063 .078
    16 .750 8.375 .070 .086
    20 .625 6.875 .086 .093
    20 .750 6.875 .093 .096
    24 .825 N/A .089 .089
    table spacing did not show up correctly: you are on your own for that
  14. #34
    Jan 2002
    Wasilla, AK
    33
    I have a copy of the print with material, tolerances, and heat treat specs. I can't figure how to post a PDF, so PM if you want a copy.
  15. #35
    Jan 2002
    Wasilla, AK
    33
    From Randall (AR15barrels.com),
    I have measured and documented dozens of different factory barrels to include diameters and lengths of every step on the whole barrel.
    From the barrel torque shoulder where the barrel extension torques against, it's 6.75" for carbine, 8.75" for mid-length and 12.125" for rifle to the step at the rear of the gas block seat.
    Breach face is 3/4" back from the torque shoulder.
    Gas port is usually 0.275" to 0.295" forward of the rear step, depending on if there is a handguard cap in the design or not.
    You should be able to figure everything else out from that...
    Unknown, but sounds good:
    On a 20" service rifle barrel the critical dimensions are as follows:
    Length from tang shoulder to gas block shoulder: 12.150" (That's the 1.000" diameter)
    (from there the barrel shoulder is angled back at 10* for 0.85"
    The gas port is 0.310 from the barrel shoulder (0.310" + 12.150" = 12.460 from barrel tang shoulder) *The diameter of that section is 0.75". *The 0.75" diameter is 1.875" long. *The rest of the barrel is 0.740"
    End is threaded 1/2-28 for .600 from muzzle. *
  16. #36
    Apr 2005
    North Bay, Canada
    36
    Excellent resource. Thanks.
  17. #37
    Apr 2005
    North Bay, Canada
    36
    Quote Originally Posted by pogo View Post
    Funny. My next question was the same as above, but for mid length. You beat me to it. Thanks!!! I will be building a mid length this week.
    BTW, for anyone interested, the 10.25" that I just built with the help of the great resources on here cylces like a charm and is VERY accurate at 25m. I am going to move out to 100 this week and see how it does.
  18. #38
    Jan 2002
    Wasilla, AK
    33
    I built a midlength to those dimensions with an, I think, 0.080" gas port. It functions pretty well. I am used to a ~15 lb match rifle, so I left it full diameter under the handguards.
    I made the barrel 17 1/2" (mistake in setting the tumbler for flash hider threads), but I will probably cut it down to 16 1/4" for looks. The midlength looks good with either the full lenth A2 buttstock or the collapsible.
  19. #39
    Jul 2010
    WA, USA
    14
  20. #40
    Jul 2010
    WA, USA
    14
