Barrel Fluting - Best Practices? - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 57 of 57
  1. #41
    Dec 2008
    Vt USA
    6,774
    738
    2322
    Quote Originally Posted by 300sniper View Post
    Parkerized? Is this a factory hammer forged barrel? If so, I'd personally avoid fluting it. The bore would almost certainly move on that.
    Why would I care if the bore "moved"?
    None of them are straight to begin with, and I sight in by pointing the scope at the bullet hole.
    It would be nice to be able to clock the barrel with any divergence up and down rather than side to side. It's a barrel with an extension,and I'm sure it's not been evaluated nor clocked from the get-go.
    What would really be nice is if the barrel didn't move around shot after shot (thermal stuff) That is the fight that's hard to win.
  2. #42
    Aug 2005
    Tucson AZ
    6,329
    9469
    2972
    These "patents" are fraudulent. 8025003B1 covers a specific shape of flute, a dove tail shape or in the bullshitese of the application "hyper undercut". The benefit is less weight. So here we have a patent on the relationship of mass to weight.
    6324780B1 is even worse. It describes a barrel with
    "an open-ended hollow body having a first end, a second end, an inner surface and an outer surface, said inner surface defining a gun barrel bore and a number of internal spiral grooves and said outer surface defining a number of external spiral grooves, wherein the number of said internal spiral grooves equal the number of said external spiral grooves"
    Then it goes on to claim that the number of grooves doesn't matter and should be equally spaced.
    I'm sure a decent patent lawyer could get the second one thrown out easily.
    The patent office is something of a joke. I know a company that has a patent on converting the drive of a crane from Morse chain to Gilmer type belt. They send you a kit of Dodge or Martin (whoever is cheapest that day) pulleys and taper lock bushings and the belt, all off the shelf items any power transmission place likely has in stock or a day away. He makes none of it, alters none of it and merely sells a group of items that other have or had patents on. This scam depends on the fact that it will cost an arm and a leg to overturn such a patent. It would also cost him an arm and leg to enforce it so go ahead and do it. Your liability is only the profit from that job. It's a civil matter, there are no fines or patent police.
  3. #43
    Nov 2006
    Greenwood, Ca
    947
    47
    308
    Quote Originally Posted by CalG View Post
    The bore diameter could change, and probably will. Just seeing examples of bores bellmouthing on forged barrels just from turning down and threading muzzles is enough to keep me from fluting one. Maybe it’ll have no noticeable affect. Maybe it will. Is the risk with it?
  4. #44
    Dec 2008
    Vt USA
    6,774
    738
    2322
    Fist off, are you of the opinion that commercial barrels are profiled and configured BEFORE they are rifled? I've never heard of such.
    First the blank, then the bore, then the outer "treatment".
    From reading your objections to post rifling operations, all barrels would be scrap from the beginning. I would not agree. All barrel makers offer "extra" machining details to existing stock. Luck is a wonderful thing.
    It's a $90 barrel, so yes, worth the risk, as the exercise will be enjoyed. I've got the advantage, I don't know how the barrel might shoot as it is! So no comparisons ;-)
    An easy barrel to resell also. Kids love "bling". ;-)
  5. #45
    Nov 2006
    Greenwood, Ca
    947
    47
    308
    “Is this a factory hammer forged barrel? If so,...”
  6. #46
    Dec 2008
    Vt USA
    6,774
    738
    2322
    Why would you think that?
    It's an after market barrel of a LR-308
  7. #47
    Nov 2006
    Greenwood, Ca
    947
    47
    308
    I did’t think anything. I asked a question. But if I was to think, I’d look at Weatherby’s site to see what they say about the H-Bar, like this: Weatherby | Vanguard Weatherguard H-Bar
    It just so happens under the features they state: Cold Hammer Forged Barrel
  8. #48
    Dec 2008
    Vt USA
    6,774
    738
    2322
    Ooohh
    So personal, like talking to a phone messaging machine.
    "I am a bull that hits like a ton of bricks, with a bull barrel to prove it. The outside diameter of my threaded 20” #3-contour heavy barrel measures a whopping .740. What that means for you is that I heat up and cool down evenly for more consistent accuracy. I’m tough like a bull too, with a tactical gray Cerakote® finish on my metalwork and a bionic one-piece machined bolt body. When it’s time to let me buck, my two-stage, match-grade trigger gives you the crisp confidence you need to make every shot count."
    I'm just not sure how that relates to bluing and it interaction with a parkerized surface.
    I guess I'll need to do some testing.
    Weatherby sure isn't going to help.
    Fluting - Lilja
  9. #49
    Nov 2006
    Greenwood, Ca
    947
    47
    308
    Ooohh
    Fluting - Lilja
    You’ve lost me. If you want to flute a factory CHF barrel, go for it. I wouldn’t do it for myself and I wound decline to take the job for a customer.
    Edit: I’m not sure what Lilja has to do with factory CHF barrels.
  10. Likes Butch Lambert liked this post
  11. #50
    Dec 2008
    Vt USA
    6,774
    738
    2322
    I read the topic regarding why has been well covered.
    Barrel Fluting
    The HOW seems to be less discussed. i.e. to the OP.
  12. #51
    Nov 2006
    Greenwood, Ca
    947
    47
    308
    Barrel Fluting
    So yes or no, is fluting a factory cold hammer forged barrel a good idea?
  13. #52
    Dec 2008
    Vt USA
    6,774
    738
    2322
    I would say NO to post hammer forged barrel fluting
    Forging induces stress, cutting through stress layers invites unknown and often unwanted motion with the stress relief.
  14. #53
    Nov 2006
    Greenwood, Ca
    947
    47
    308
    So the above replies to me asking if this was a factory hammer forged barrel and my opinion that if so, it isn’t a good idea was?
  15. Likes Butch Lambert liked this post
  16. #54
    Dec 2008
    Vt USA
    6,774
    738
    2322
    Perhaps you should start a thread on the topic.
  17. #55
    Dec 2008
    Vt USA
    6,774
    738
    2322
  18. #56
    Nov 2006
    Greenwood, Ca
    947
    47
    308
    I’m really confused. Why would’ve I start a thread on it? I responded to a poster here and you seem to have issues with that response, then you say you agree with my opinion.
  19. Likes Butch Lambert liked this post
  20. #57
    Aug 2018
    17
    6
    Good tip he's not too far from my shop. The problem I have with anything that modifies the barrel, including rails, and scope mounts, and contacting forearms, and hanging any gizmos from a barrel, is the disturbance of the barrel's natural harmonic frequency. Now you have an unpredictable barrel harmonic and therefore inaccurate. I'll stick with basic straight barrels and eliminate the chances for screwing with the laws of physics.
