Concerns.... plenty..
You keep coming up with the most unsafe ideas I can think of..
460 S&W Mosin... TIG Welding all around the chamber... and on 316 SS to boot.
Here is what I suggest.
Go to a Gunsmithing school/collage, say around 2 years.. No a set of DVD's will not cut it...
Or get a Mechanical Engineering degree.
Or at least, get to be a certified pressure vessel welder. You will learn how metals react/change when welded...
This is not a put down..
When an action or barrel fails, parts (often heavy parts) go flying in all directions.
All too easy to kill, maim, blind, an innocent bystander, or yourself..
Get some F'n training, before you hurt someone...
Trying to save a buck on a high pressure device, is just not the way to go. Although a Savage style nut is fine... It does limit OD of barrel
Do it right, or do not do it... You only get one life...
Search for SAKO Barrel failure, M1903 Springfield receiver failure, Mauser receiver failures.
In the case of SAKO and the Springfields.. Even big Companies and Gov't Arsenals, screw up.. People get hurt..
There are many good books like: Bolt Action Rifles written by Frank De Haas. Clearly explains action strengths/weaknesses and recommended caliber/pressures.
Many other books out there, that are also useful in providing reasons to, or not to, modify firearms.. Hatchers Notebook. The Modern Gunsmith by Howe etc..
