Barrel Tenon Size
Results 1 to 18 of 18
    Jul 2019
    North Dakota
    7
    Default Barrel Tenon Size
    I have several chambered, threaded blanks that i need help identifying. Shank is 1.00 diameter with 16 TPI and a length of 1.00.
    Any idea what action thiese are designed to fit?
    Dec 2017
    Idaho
    369
    104
    87
    Tikka, maybe??? Can’t remember the length, but threads and diameter make sense
    Feb 2001
    Arizona
    2,252
    365
    I would be surprised if a Tikka didn't have metric threads.
    Dec 2012
    AUSTRALIA
    3,403
    14
    1138
    Ruger use 1"x16v...........I think Winchester Mod 70 too.
    Jul 2019
    North Dakota
    7
    Quote Originally Posted by john.k View Post
    The part that's throwing me off is the length of the tenon
  6. Likes Mram10 liked this post
    Aug 2012
    Canada
    155
    91
    22
    Perhaps early Sako L-61 which used 1x 16tpi. They also list AV1 and AV4 in the notes I have. I am not certain about the shank length however.
    Dec 2017
    Idaho
    369
    104
    87
    Quote Originally Posted by GGaskill View Post
    I’ve built 2 tikkas and the 1-16” worked for them. Not older actions
  9. #8
    Apr 2008
    West Coast
    298
    60
    56
    What chamber? As noted, lots of actions use 1"-16 TPI. If you can determine the cartridge, check the chamber depth with a GO gauge. Could be a "deep chambered" pre-fit designed to adjust head space by machining tenon and torque shoulder to fit receiver/bolt combination.
  10. #9
    May 2019
    Arkansas
    146
    17
    83
    Tikka T3 is 1”-16
    ETA: beat to it a few times over. I save all of the t3 barrels I pull, they are fantastic barrels that I end up repurposing quite a bit.
  11. #10
    May 2019
    Arkansas
    146
    17
    83
    Just measured a couple culprits. Model 70 and Tikka T3 threads are both 1-16 TPI, however tennon length on the model 70 barrels I could find averaged around 0.700", while the 5 T3 barrels were all dead nuts at 0.9855".
    That's one thing I love about the T3 compared to some of the trash coming out of some of our factories now (looking at you Remington), the machining is fantastic, and you go to blueprint one and realize the it's already really, really good. I had to take almost 0.100" off a new factory 700 receiver to get it square, and the threads were way crooked, kind of like Freedom Group's upper management.
    OP, if you didn't use a depth mic, or were rounding up, I'd say you may have a Tikka barrel. Up until about ten years ago, they were unmarked.
  12. #11
    Dec 2017
    Idaho
    369
    104
    87
    I’m shocked the Rem required that much! I’ve trued up a bunch of newer ones and haven’t needed more than a couple thousandths to square the receiver face
  13. #12
    May 2019
    Arkansas
    146
    17
    83
    Quote Originally Posted by Mram10 View Post
    It’s certainly extreme, and it’s a little unfair that I didn’t mention that I’ve done over 1k 700’s and that was the worst one. Some of them from the 1970’s have been fantastic.
    That said, if Remington’s standard is still the same as right after they were acquired by Cerberus, they can hydraulically press a barrel up to 0.02” to meet headspace!!! For a guy with a gunshot wound in one arm and missing fingers on the other, it can make it hard to remove factory barrels without parting them by the recoil lug.
  14. #13
    Jun 2007
    OK
    269
    8
    41
    Quote Originally Posted by 9finger View Post
    Are you sure you didn't misplace a decimal? .010 sounds more reasonable. There is no way a receiver would be out .100. Is that measured on the face?
  15. Likes Mram10, Lharmon liked this post
  16. #14
    Jun 2007
    OK
    269
    8
    41
    I too have an unknown barrel tenon I'm trying to identify 1"-16 1.100 length, flat breech.
  17. #15
    Apr 2008
    West Coast
    298
    60
    56
    .... I had to take almost 0.100" off a new factory 700 receiver to get it square, and the threads were way crooked....
    If it was that bad, why didn't you send it back?
  18. #16
    May 2019
    Arkansas
    146
    17
    83
    Quote Originally Posted by kendog View Post
    I've gone down that road with remington, not something I'll do again. I just trued it up best I could, and built a .300 blk subsonic only build and used another action, not far off on S/N: that was less than 0.002" off, with good threads, for the build that action was planned for.
    As I said, that's the worst I've seen from them, and second worst was not near as bad, and that is out of a lot of actions over the years. But, when I have the choice, I'll use aftermarket actions, other brands, or for myself, build my own (and usually never finish them.)
  19. #17
    May 2019
    Arkansas
    146
    17
    83
    Quote Originally Posted by ndh78 View Post
    Tikka marks the breach face with caliber and twist, usually, but I have some older ones that are not.
  20. #18
    Nov 2006
    Mesa, AZ
    27
    Ruger American takes a 1"- 16 and flat breech face. I just chambered one and did not reuse the nut.
