Black powder barrel made of carbon fiber?
Hello, I’’ve seen thin steel barrels wrapped in carbon fibers on modern guns.
Since carbon fiber has a very high tensile strength and also is a very light weight material,it make sense. However, I want to take this a step further. I thought about the possibility to make a barrel made of 100% carbon fiber - without the inner barrel made of steel.
Since black powder has a much lower pressure rate than modern gunpowder, I will load it with BP/pyrodex only.
What’s the minimum wall thickness, for caliber .40-.50, propelled with ~20-35 grains FFFG BP?
Can I prevent the barrel from catching fire by avoiding rapid fire? Or by using a thin inner barrel of carbon fiber, that can be replaced and cool down between each shot? Impregnating the bore with flame retardant could also be an alternative.
What kind of carbon fiber pipe are ideal in this application?
