Peter Colman
Stainless
- Sep 22, 2004
- Rugeley UK
I have a Steyr grey ABS rifle stock that has broken between the bolt recess and the trigger slot. This is on one side only so I plan to cut a slot in the plastic and let in a stainless steel strip with holes in it and glue the strip into position and run the glue into the crack.
My first question is what glue to use..
My second,problem is how to remove scratches and shiny areas to improve the cosmetic appearance of he stock.
