partsproduction
Titanium
- Aug 22, 2011
- Oregon coast
I'm not a gunsmith, and many of you probably know the best way to repair this.
I believe it's a Montgomery Ward, but I'm still waiting for the model #. With that I can check with Jack First, but the one from a different model at Bob's was $87 something, again, holding for the model number.
If that fails I plan on making a replica for the end, heat treat it and my friend, a professional welder, can either weld it to the original remaining op rod or silver solder it, and I suggested to do it on a bias per the drawing.
The two photo's won't download, and JF says they don't have any parts for that model #
OK, I got the model #, it's Western Field 6060-SB602-A
My plan was to carefully clamp the O-1 end next to the original as per the sketch, then either silver solder or skip weld, clamped to an aluminum heat sink in either case.
Also, if any of you know where else we could look for a replacement part we may avoid any weaknesses such a repair might add. The end away from the hook is screwed to the tube inside the wood slide handle, but the tube comes out of the wood part.
parts
parts
