Black Powder Shotgun Barrel Material
Results 1 to 12 of 12
    Sep 2017
    Oregon
    5
    Default Black Powder Shotgun Barrel Material
    I'm wanting to build a couple black powder shotguns and a punt gun/wall gun but I'm having trouble finding specs for the barrel steel, I was thinking of using seamless 4130 tubing. 1" OD a .156 or .188 wall thickness and either a 1.125 or 1.25 OD with the same wall thickness for the shotguns. Would that work? Maybe with a 8-10" sleeve to reinforce the the breach area?
    Now for the the punt gun, I don't really have a frame of reference, I've seen a couple videos that look like they used 2" OD with a .25" wall but I'm not sure if they were just signal cannons or if they were functional guns.
    Mar 2007
    southcentral WI
    63
    5
    DOM steel would work for black powder only, but take a look at SARCO, they had some unturned shotgun barrel blanks listed recently.
    Jul 2004
    Houston, TX USA
    29,769
    Quote Originally Posted by msalm View Post
    All DOM tubing is welded - sure would not catch me expecting it to reliably hold substantial pressure
  4. Likes MetalCarnage liked this post
    Feb 2001
    Arizona
    2,208
    340
    Do the math. Use the thick wall formula. The problem is determining what an accurate pressure value is. And don't forget a safety factor.
  6. Likes Will_White liked this post
  7. #5
    Mar 2007
    southcentral WI
    63
    5
    'Substantial' pressure is not much with black powder. I have quite a few pre1880's firearms and DOM has more going for it than many originals had available even.
    An uncle of mine built a lot of muzzleloaders and restored a lot of originals. He remarked to me once that really almost any modern steel with a hole in it was superior to what was available and used in the 1700-1850's. he was an old school machinist and did wonderful work. Black powder is not high pressure in comparison to the smokeless powders and steel requirements for it. The fact that Damascus barrels held up with even .050" walls or less towards the muzzles was amazing to me but he still shot many of those originals with no problems ever.
  8. #6
    Mar 2006
    New Jersey
    1,088
    13
    297
    We did some testing here with 3/4" black pipe and 12ga 3" shotgun shells. The results show that it will withstand the pressures. Not that it makes a nice barrel, but it is probably the weakest tubing out there.
  9. Likes Will_White liked this post
  10. #7
    Sep 2012
    California, Ventura county
    1,415
    256
    602
    yup they didn't have fancy steels available in those old days
    even a modern barrel isn't particularly hard.
    wasn't there a guy here making 45-70 barrels out of 1018
  11. #8
    Sep 2017
    Oregon
    5
    Quote Originally Posted by GGaskill View Post
    That's a good resource, but I'm not really sure what the numbers actually mean. For example, if I input 1.5" ID with a .5" wall thickness and a 25000 PSI pressure, which I did some research and found a couple places that say black powder cartridges pretty much max out at 25000psi with shot shells being significantly less, I get 53125. Is that the tensile strength of material needed to contain that pressure?
  12. #9
    Sep 2017
    Oregon
    5
    The hoop stress link is helpful, but I'm not sure exactly what the results mean. For example, if I input 1.5" ID, .5" wall, and 25000psi, which is a number I found on a couple of sites as the max pressure of black powder cartridges, I get 53125. Is that the tensile strength of material needed to contain that pressure? I've tried pudding this a couple times and it wouldn't post.
  13. #10
    Feb 2001
    Arizona
    2,208
    340
    53125 psi is the stress in the material given those dimensions and that pressure. My recollection is BP shotshell pressure is less than 8000 psi. I am guessing that those dimensions are for the punt gun. The real problem in sizing material for BP guns from calculations is lack of accurate pressure data. Annealed 4140 would give you some safety factor.
  14. #11
    Jul 2004
    Houston, TX USA
    29,769
    What black powder can do to not so hot metallurgy
    Scroll down to 1844 Peacemaker Accident
    USS Princeton (1843) - Wikipedia
  15. Likes MetalCarnage liked this post
  16. #12
    Sep 2017
    Oregon
    5
    Coming back to this project, found that my source for odd lengths of steel now has seamless normalized 4130 round tube. I'm now thinking about starting small with a .375 cal musket out of .75 OD .375 ID tube. Does this seem like a good place to start?
