Bolt flutes
Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: Bolt flutes
    Feb 2007
    UK
    73
    Post
    Could any one kindly explain the proses of helical fluting a bolt on a rifle. I guess you whuld use a mill and a bull head cuter but what methods are used a simple explination whould be great thanks.
    May 2005
    Interior British Columbia
    2,268
    235
    689
    Post
    You need a mill that will drive a universal indexing head for helical cutting, or a CNC mill with a 4th axis, and a controller that can handle the simultaneous moves.
    The universal indexing head has a gear train between the leadscrew of the table and the input shaft of the indexing head allowing a consistant ratio between the lead of the screw and the worm gear ratio, which allows rthe indexing head to turn a determined amount as the table moves a given distance, which gives you the helix.
    There is a bunch of math involved in calculating the gear trains, or you can look it up on the chart that should be with the head.
    Cheers
    Trevor Jones
  3. Likes Butch Lambert liked this post
    Nov 2006
    littlestown,pa
    1,763
    72
    20
    Post
    But whats the reason for them?
    Apr 2005
    Vallejo,Ca USA
    207
    Post
    Looks cool,no other reason.
  6. Likes Butch Lambert liked this post
  7. #5
    Sep 2004
    North Olmsted, Ohio
    91
    12
    Post
    Lumpsmith
    The benchrest guys do it to reduce weight so a heavier stiffer barrel can be used.
  8. #6
    Apr 2007
    N. MN
    153
    Post
    I think Walker nailed it. I have a gun that I picked up at a gunshow where the folks that built it didn't have the technology to do the spiral fluting. The bolt (XP-100 action) was reduced in diameter (between the lugs and bolt-handle) and the dog-leg was drilled full of holes to get the gun under the legal limit. It also have a very short, heavy barrel.
  9. #7
    Jan 2007
    Sierra Nevada Mountains - Motherlode, CA USA
    552
    12
    Post
    I believe they are for either esthetics or weight loss (minor). My Remington 700 Titanium has spiral fluted bolt, seems only to reduce more weight.
    I was just thinking out of the box and I could easily cut spiral flutes on a bolt with my Monoset.
  10. #8
    Apr 2005
    Vallejo,Ca USA
    207
    Post
    To make them "lighter" you got to be kidding. How much weight do you think is in those little cuts? Now the ones on the bbls might reduce the weight a noticable amount also the ones on the bbl help to cool the bbl,more surface area.
  11. #9
    Feb 2007
    UK
    73
    Post
    Thanks, i think they are just for show and are personal taste. i was interested to know how they were cut though.
  12. #10
    Jul 2003
    VA
    301
    10
    Post
    A fluted bolt does reduce weight some. There are other places where you ca shed some ounces.
    It also helps in making the bolt smoother to the feel of operation. Less surface area means less drag or friction. The diameter stays the same, but much less drag.
    The spiral is just one way of doing it, there are straight flutes, and even diamond pattern flutes. All serve the same purpose.
  13. #11
    Dec 2005
    Kalispell, Montana
    1,256
    12
    Post
    Lumpsmith,
    BR guns have to weight a certain amount for a given class, the less weight you pack else where means the more you can put in the barrel. Yes, trivial amounts but it can and does make a difference
    Jim
  14. #12
    Feb 2007
    UK
    73
    Post
    I think it has to be more for fancy than any other thing.
    The angled flutes and the bolt drag point?
    ... Whould you not think that straight flutes whould be more practical at smothing bolt operation? Or am i mising some thing.
  15. #13
    Apr 2005
    Vallejo,Ca USA
    207
    Post
    I realize that there are weight limits for the different classes,and I am not trying to be a "richard head" but you are'nt going to save enough weight to make it worth the time and money. the only thing that is lighter is your wallet.
    Do you remember the big to do in the hot rod world when Isky cams came out with their 5 cycle cams? It was going to revolutionize the hot rod/racing world never happened because it was all hype. In my opinion this is the same thing.
  16. #14
    Oct 2002
    Poetry Texas USA
    1,776
    321
    222
    Post
    My BR bolts are helical fluted in a diamond pattern. Yes it saves a little weight, but more importantly it is smoother as our bolts are a very close tolerance fit unlike a production bolt. Gives a little space for trash to fall into. My BR bolts have only .001 total clearence. No room for a little trash.
    Butch
    www.shadetreeea.com
  17. #15
    Sep 2006
    32
    Post
    If you use straight flutes on a bolt, it is possible in certain rifles/calibers that the top cartridge in the magazine will rise up into one of the flutes when rotating the bolt. Not good.
    If you use helical flutes this problem is avoided.
    Yes you are removing only a very small amount of weight but there is a saying,"watch the ounces and the pounds will take care of them selves".
  18. #16
    Apr 2019
    South Carolina
    Fluting a rifle's bolt theoretically gives debris and dust a place to sit without compromising the rifle's functionality. However, unless you're fighting in the trenches of Passchendaele, or Operation Torch in the Sahara of Africa, Your rifle's fluted bolt isn't going to give you any actual advantage in real life.
    Some might disagree with me, citing that fluting the bolt contributes to weight reduction; to that, I concede. However, a fluted bolt reduces the rifle's weight to such an insignificant degree that, unless you're focused on making the lightest rifle physically possible and have an excess of money at your disposal, you are better off just buying a normal bolt or just using the factory bolt.
  19. #17
    Nov 2006
    Greenwood, Ca
    947
    47
    308
    Quote Originally Posted by jabezkin View Post
    To make your wallet lighter.
  20. Likes Butch Lambert liked this post
  21. #18
    Nov 2006
    Greenwood, Ca
    947
    47
    308
    I’d argue that fluting the bolt body of a 2 lug bolt in the ejection port area has zero benefit, and probably had more potential for lockup from debris than a smooth bolt body.
    As far as weight savings on BR rifles, there’s probably more weight in fancy stock paint than was saved by fluting the bolt...
    My personal rifles have smooth bolts. My available for purchase rifles/barreled actions have fluted bolts. I don’t believe in them, but I have to sell what people want/think they need.
  22. #19
    Oct 2002
    Poetry Texas USA
    1,776
    321
    222
    Quote Originally Posted by 300sniper View Post
    You sell the sizzle, not the steak!
  23. #20
    Dec 2017
    Idaho
    369
    104
    84
    I weighed a couple long action Rem 700 bolts and it saves maybe an ounce with spiral flutes. They shoot better though 😀
