Broken Scope mount screw
Likes Likes:  0
Results 1 to 9 of 9
    Apr 2003
    Taberg, NY , US
    60
    I have a broken scope mount screw and need to know methods of removing it ..
    The smallest EZ-OUT is 1/16 inch .. that I can buy .. much smaller and it would prolly break trying to use it anyways ..
    Comments, suggestions ??
    Nov 2002
    3,251
    1843
    805
    Left handed drill!!! Don't bother with an EZOUT... they suck! It WILL break, and then you have a hardened peice of metal inside the screw. A left handed drill bit will probably spin it right out.
    Apr 2003
    Locust Grove Ga USA
    190
    What doug925 said!
    Robert.
    Apr 2003
    Taberg, NY , US
    60
    Theres enough metal to get to that I can smooth the top off to put a center drill on it to start the hole before using the leftie drill .. is that ok ?
    Apr 2003
    Locust Grove Ga USA
    190
    That would be perfect.Just don't spin it to the bottom of the hole and jamb it.
    Robert.
    Apr 2003
    Taberg, NY , US
    60
    oh yeah ..
    cause center drills are right handed ..
    hmmmmmm
    Jul 2003
    Linwood, Ma USA, the center of the known universe
    274
    Have you tried using a center punch near the edge yet. Or you could use a vibratory engraving pen. Have never had a scope mount screw fail to come out using those two methods.
    Paul G.
    Apr 2003
    Taberg, NY , US
    60
    I'll give the center punch a try this weekend
    Apr 2003
    Taberg, NY , US
    60
    The center punch method worked ..
    Thanks very much
