Bullets in flight visible
Page 1 of 2 12 LastLast
Results 1 to 20 of 32
    Nov 2004
    Webster Groves, MO
    6,747
    1669
    2979
    Default Bullets in flight visible
    I just watched a program about the recent terrorist attack on a Nairobi shopping mall.
    Al-Shabab terror attack in Nairobi shopping district angers Kenyans - Washington Times
    The mall has very good surveillance cameras, sharp pictures instead of the blurred ones we often see. Several times the terrorists fired their AKs and long streaks could be seen extending from the barrels to the picture's edges. I have seen .22 bullets when the sun was exactly right and once saw a .44 bullet in flight, but these are rare occurrences. In the videos, nearly all the streaks were visible. I am guessing that the images imprinted on the CCD pixels and remained there for at least one scan, possible more, which would mean they would be on screen for at least 1/70 second.
    Has anyone else seen this effect?
    Bill
    Jun 2006
    Near Seattle
    4,606
    2799
    1204
    The web page doesn't like my browser, but I have seen "bullet trace" - the air trace a bullet leaves when fired from a rifle - at a long range shooting event.
    Are you talking about that or something else?
    Aug 2012
    Canada
    129
    74
    16
    I have seen bullets in flight. It's easiest to see when the sun is lower on the horizon and is at your back. I used to see them all the time when I shot in a pit that had steep limestone walls. Made for good contrast of the copper color of the bullet jacket shining in the sun against the grey limestone. Image persistence in the human eye makes object that appear briefly, to be perceived to persist for a longer duration. It's why if you waive a sparkler or glowing end of a stick at night, you see a trail, even though it should simply be a moving point.
    I think you are seeing the gasses from the muzzle, not the bullet. I can't imagine a standard CCTV camera capturing the bullet itself in flight.
  4. Likes DrHook liked this post
    Aug 2012
    Bedford, IN
    952
    82
    300
    Is it possible they were tracers and imparting a ton of photons on the image sensor as they streaked across the picture? Possible they were tracers that were old and the tracer compound was leaving a small smoke trail?
    Otherwise, it's not unusual to see bullet trace if the conditions are right but to see a full trace like that sounds odd.
    Sep 2010
    Oklahoma City, OK
    3,857
    673
    1677
    It's pretty easy to see .45ACP in flight if you're directly behind the shooter.
  7. Likes 5 axis Fidia guy liked this post
  8. #6
    Nov 2004
    Webster Groves, MO
    6,747
    1669
    2979
    The trace was more or less brass colored and they extended from the muzzles to the edge of the frame, probably 10 or so feet away in both cases. The first one was continuous and about the same from one end to the other. It was definitely not air turbulance. The second example was several shots about the same color but interrupted, lines about 6" long with 2" spaces between, like the dashed lines we see on prints.
    As I understand CCD, the cells are receiving light all the time and the scan resets them. If so, all the cells could have received reflected light from the bullets and then read in sequence. Those images would stay on the computer screen until the next scan. In each case, the flight was roughly horizontal so that the row would be scanned close together.
    After typing this, it occurred to me to look for a video on the net. This is not the one I saw on TV and the streaks do not look quite the same, possibly from lighting differences.
    YouTube
    look at 24, 25 and 48 seconds.
    Bill
  9. #7
    Jun 2012
    Michigan
    9,294
    3161
    3342
    Quote Originally Posted by 9100 View Post
    YouTube
    Bill
    and 154s poping that guy on the floor
    That we need to get serious and start Hanging such bad guys. See someone hang and lot likely to do the crime..
    Life in a jail with visitation with your buddies and three square meals is not deterrent.
  10. Likes DrHook liked this post
  11. #8
    Jun 2006
    Near Seattle
    4,606
    2799
    1204
    Looks for all the world like you'd think a tracer would look (I've never fired one) - and why would terrorists bother with tracers?
  12. #9
    Aug 2018
    Tennessee
    58
    38
    14
    I've been an long and extreme long rifleman since I was 12. "bullet trace" or "vapor trails" off bullet can near always be seen, so long as the bullet is super sonic. The trick is to get immediately behind the bullet, and near as close to bore line as possible with (good) optics. In sniper competitions, my spotter, or if I'm spotting sits immediately behind the shooter. The optic It lowered as much as possible to the height of the bore line, without the shooter blocking in the view. This is how awesome and world class long range competition teams can call a shot correction to the shooter before the bullet actually get's to the impact area. (Obviously only possible at near 1000 yards and beyond.
    Ballisticians and physicists debate what causes the phenomenon. Some are in the camp that the shock wave atomizes/boils the moisture in the air, others are in the camp that is the shockwave on the bullet is distorting the light waves....
  13. Likes michiganbuck, 9100 liked this post
  14. #10
    Jan 2007
    Flushing/Flint, Michigan
    7,115
    341
    6022
    As I understand CCD, the cells are receiving light all the time and the scan resets them...
    No and sort of. The internal refresh may be way higher than the sent out frame rate.
    Also wonder why you think this CCD and not CMOS.
    Lots of light here, the camera would clamp the integration time way down to stay out of saturation.
    Bob
  15. #11
    Nov 2004
    Webster Groves, MO
    6,747
    1669
    2979
    Quote Originally Posted by michiganbuck View Post
    Problem is they want that. Dying in public for their sick god is about the best end they can have. I favor beating them to death with a pig carcass.
    Bill
  16. Likes DrHook liked this post
  17. #12
    Jun 2012
    Michigan
    9,294
    3161
    3342
    Dying on a rope with no fanfair ,, not even their name said..just a terrorist was hung today . then his body laid to read on top the garbage pile for the birds and rats to spread far and wide..(so he/she cant go to La La land.) This was an old First Nation way to get rid of some who might come back to haunt you.
    I used to have fun with 8mm tracers. cant seem to find them anymore.
    OH there they are $25 a box.
    COLLECTORS AMMO | Product Categories | Allegheny Arsenal
    Great Lakes First Nation tribes:
    Indians in the Great Lakes region
    It is said Etienne Brule' went this way with bones spread far and wide..
    His story:
    Etienne Brule Gets Cut Up Into Pieces And Then Eaten
    That must have worked because he never came back.
  18. #13
    Aug 2012
    Bedford, IN
    952
    82
    300
    Quote Originally Posted by bryan_machine View Post
    They're readily available as comm-bloc surplus in many places.
  19. #14
    Aug 2005
    Manchester, MD
    251
    27
    I've seen some video shot from the turrets of tanks as the main gun is fired. The rounds are clearly visible traveling through the air. It is not like the vapor trail in the video linked above.
  20. #15
    Sep 2012
    California, Ventura county
    1,391
    254
    600
    Bill
    nah feed em to the pigs live ending up as pig crap is scare to them
  21. Likes garyphansen liked this post
  22. #16
    Feb 2011
    1,862
    1123
    767
    (I've a soft spot for Garands) This one's kinda cool to see it spiraling through the air and hitting the mark.
    Seeing the bullet from behind isn't too uncommon. From the side, I think the air trace is the closest your human eyes/mind can catch.
  23. Likes michiganbuck, DrHook, 9100, Grizzlypeg liked this post
  24. #17
    Sep 2010
    Oklahoma City, OK
    3,857
    673
    1677
    and a guaranteed recidivism rate of 0.
  25. #18
    Jan 2012
    SW Missouri, USA
    35
    8
    yes; I could watch my 45ACP bullets in flight when the light was right.
  26. #19
    Jan 2005
    Houston
    5,424
    451
    2283
    I've seen skyrockets in flight. It was an afternoon delight.
  27. #20
    Nov 2004
    Webster Groves, MO
    6,747
    1669
    2979
    Something else occurred to me. How hot are bullets? Many cameras are sensitive to infrared. We may be seeing the bullet itself glowing. Between powder burning, barrel friction and air friction, there must be a lot of heat generated. The difference between muzzle energy and 100 yards would be an indication and that could be related to the mass of the bullet to make an estimate.
    Bill
  28. Likes Peter., bryan_machine liked this post
