Centering Pre-Threaded Barrel Up For Chambering
Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Sep 2004
    AZ
    70
    Default Centering Pre-Threaded Barrel Up For Chambering
    I've always installed bare blanks or pre-threaded and short chambered barrels. A customer brought in a pre-threaded but un-chambered carbon barrel the other day. 99% of the time i chamber through the headstock and dial in off the bore at both ends. I dialed in the blank to thread for a brake in the same fashion and after if was dialed in I measured the off of the portion of the tenon that rests under the recoil lug, its off by several thou. I'm sure the threads are off by this much also. I cant recut the threads and I would think its more important for the chamber to be spot on with the bore. I can re-cut the shoulder on the barrel after dialing in which might help. Any suggestions??
    Dec 2017
    Idaho
    369
    104
    83
    I’d dial in the bore than true up the shoulder. Keep it simple. Bet it will still outshoot the shooter
    Jul 2007
    Arizona
    24
    show the customer, explain the problem,
    explain the time and cost to fix the problem
    re-cut threads and shoulder, by picking up the current thread and re-cutting.
  4. Likes Kurt Learning liked this post
    Dec 2017
    Idaho
    369
    104
    83
    Quote Originally Posted by mike in co View Post
    Why pick up the current thread if you are recutting?
    Nov 2006
    Greenwood, Ca
    944
    47
    306
    Dial in the throat and chamber it. The shoulder was cut at the same time as the threads. Anything you do to it in a new set up is going to be less perfect.
    Jan 2009
    Georgia
    71
    7
    8
    Dial the bore in, leave the threads alone and make sure the cartridge has a little room in the bolt face.
    Dec 2017
    Idaho
    369
    104
    83
    There is a bit of play in the threads, so cutting the shoulder after dialing in the bore would help. Just my 2 cents
  9. #8
    Nov 2006
    Greenwood, Ca
    944
    47
    306
    Quote Originally Posted by Mram10 View Post
    What will you accomplish by this?
  10. #9
    Oct 2002
    Poetry Texas USA
    1,760
    316
    215
    Reach in and dial the bore in the neck and at the back of the chamber. Check the shoulder.
  11. #10
    Dec 2017
    Idaho
    369
    104
    83
    Quote Originally Posted by 300sniper View Post
    Verifies the shoulder is perpendicular to the bore. Should mate up square with the action face. Keeps everything square. I’m sure there are other ways, but this makes sense to me and what I’d do
  12. #11
    Nov 2006
    Greenwood, Ca
    944
    47
    306
    What difference is that going to make over the diameter of the bolt face? How far out do you think it could possibly be?
  13. #12
    Dec 2017
    Idaho
    369
    104
    83
    If you are dialing it in on the lathe to see where it stands, it takes no time to square the shoulder. Just my humble opinion
  14. #13
    Nov 2006
    Greenwood, Ca
    944
    47
    306
    And by doing that, you are taking two locating features that were absolutely perpendicular, and almost certainly making them out of square, for absolutely no gain.
    I’d be curious if anyone can claim they chambered a barrel with near zero runout in every spot from 2” in front of the throat to the breech, then completely removed it from the machine, put it back in the machine, indicated in in the same way originally done, and still found zero runout over the same length.
  15. #14
    Dec 2017
    Idaho
    369
    104
    83
    So I dial in the barrel via the bore, trim the shoulder so it is perpendicular and it will take them out of square? I disagree
    I do agree with your zero runout example though.
  16. #15
    Jan 2009
    Georgia
    71
    7
    8
    What he means is that since the barrel was threaded in a previous setup, re-cutting the shoulder in a different setup without re-threading will leave the threads and shoulder out of square.
  17. Likes Butch Lambert liked this post
  18. #16
    Nov 2004
    RC, CA
    1,970
    211
    374
    Effectively, the same thing as screwing a new barrel into an untrued action.
  19. #17
    Dec 2017
    Idaho
    369
    104
    83
    Quote Originally Posted by jasonixo View Post
    As I posted above, there is enough slop in threads that the barrel shoulder and action face will mate without recutting threads.
  20. #18
    Dec 2017
    Idaho
    369
    104
    83
    Quote Originally Posted by wesg View Post
    I assumed the action face was already trued up.
  21. #19
    Sep 2015
    Florida
    586
    84
    I'll be the odd man out on this one.
    I'd do this barrel between centers. I often do anyway, but in this case since the thread tenon is already cut I'd work off of that. No reason to assume the shoulder and threads aren't perpendicular.
    Many manufacturers want an inch cut off each end anyway,so I cut small 60 degree centers with a reamer, make a truing cut on the muzzle end, flip it around and put in the set-tru or collet(or drive it with a dog). Set the steady on the threads and chamber.
    I would't take the time to dial in through the headstock as some of the work has already been done, and the small incremental gains that may be made by painstakingly dialing in through the headstock have already been mitigated by the tenon and shoulder being cut, and a second setup won't get that back.
    As the saying goes...JMO...
  22. #20
    Sep 2014
    UNITED KINGDOM
    18
    8
    Quote Originally Posted by tobnpr View Post
    I am just curious as to how you would chamber a barrel between centres?
