Chambering barrel
Results 1 to 13 of 13
    Dec 2018
    Oklahoma
    Default Chambering barrel
    So Im looking to build a lr/elr hunting rig in 300wm. Looking to use a Bighorn SR3 and a carbon wrapped barrel. My friend that has a lathe and does some smithing and has threaded and crowned barrels for brakes. What he does not have is a spider. My question is is it feasible to chamber a carbon barrel on centers without marring the carbon in the steady rest and if so how did you manage this?
    May 2015
    Nevada
    Default Viper Chambering FIxture
    Quote Originally Posted by creekrat View Post
    I would highly recommend contacting Bob at the site listed below. Take a look at his cambering fixture - second item on the page as you scroll down. His contact information is at the bottom of the page. The man is a master machinist and a prolific champion 1000 yard and F Class bench rest shooter....knows his stuff.
    F Class Feet for The Viper
    Tell him Dale in Reno, NV says hello.
    Jul 2011
    Brusly, LA
    764
    21
    302
    Between centers with a steady on a cf barrel I don’t think would work very well.
    Ideally you’d want to use something like the Tru Bore alignment system or at least a cat head Chuck with a sleeve fit over the barrel where the set screws touch it.
    Sep 2015
    Florida
    665
    98
    You can use a spider in the steady as mentioned here, or you can press-fit a sleeve over the barrel just ahead of the area to be worked.
    Same technique as used when needing to do a re-crown, or threading a muzzle between centers. If necessary depending on barrel taper, you may need to bore to match the contour (I've also done a quick cast with epoxy in a sleeve so it precisely fits the contour). Place it on the barrel with the breech in a precision live center (or dead center with some STP lube as it's a quick op, make a facing cut to true the OD to the bore. Place the steady to ride on the trued collar and get to work.
    I still chamber between centers sometimes, with a steel barrel the truing cut is done directly on the breech cylinder of the barrel, same idea here except use a sacrificial sleeve over the cylinder instead.
    If the spindle bore is large enough, it's pretty simple to make a spider to fit if you'd rather chamber it through the headstock.
    Aug 2005
    Tucson AZ
    6,421
    9760
    3023
    Quote Originally Posted by tobnpr View Post
    How does a face cut " true the OD to the bore"?
  6. Likes Butch Lambert liked this post
    Sep 2015
    Florida
    665
    98
    Spoke incorrectly, meant to say "skim" cut (parallel to Z)- not facing.
    Sep 2018
    ALAND ISLANDS
    65
    22
    After spending that much on a barrel blank, I wouldn't want it chambered between centers. Building a spider isn't hard.
    Sent from my Pixel 2 using Tapatalk
  9. #8
    Mar 2019
    ALAND ISLANDS
    33
    22
    13
    Run the steady on the barrel tenon. Itís still steel, yes?
  10. #9
    Sep 2018
    ALAND ISLANDS
    65
    22
    Quote Originally Posted by gbflyer View Post
    But it's not likely centered on the bore. You would typically take a light cut on the cylinder portion of the contour, this is not practical on a proof.
    Build a spider, buy a prefit barrel or bring it to a gunsmith.
  11. #10
    Mar 2019
    ALAND ISLANDS
    33
    22
    13
    Quote Originally Posted by pat_j0nes View Post
    Hmmm...OK. Donít you still have to cut the tenon diameter and thread a Proof? Guess Iíd better try one. Itís carbon wrapped in the middle with steel showing on both ends, yes? I fail to see why chambering between centers wonít work just like any other barrel. Iím no pro but if I didnít have a spider I would put good centers in each end with a piloted center cutter, true the muzzle end if that makes you feel better, flip it around, drive the muzzle and bring the breech up to a center in the tailstock, cut the tenon, thread it, run the steady fingers on the threads and chamber it. I then would screw a trued threaded collar on the threaded tenon, flip it over again and do my work on the crown. Betcha it would shoot just as well as one setup in a spider.
    Still plenty of fake wood winning barrels being chambered between centers. Setting up in a spider is fine but sometimes it doesnít work due to a worn out machine or barrel limitations. A good Smith will turn out a quality product anyway.
    I really really really doubt that a lot of the big name smiths go to all the setup trouble their websites say they do...chamber jobs would be $1000 labor if they did. I had a very competitive switch barrel BR rifle on a Stolle Panda with multiple Harts built. I was present for the work as an observer and there was not a spider, carbide boring bar, or a test indicator or a Gritter rod in sight. Chambering barrel
    This is just how Iíd do it. I donít have to make a customer happy. Iím the customer. Ha! Just suggesting to the OP that there could be another way to go if he wishes to tackle it. As always, free advice worth the price.
  12. Likes tdmidget liked this post
  13. #11
    Oct 2002
    Poetry Texas USA
    1,802
    343
    235
    Chuckle chuckle, Still plenty of fake wood winning barrels being chambered between centers. Setting up in a spider is fine but sometimes it doesnít work due to a worn out machine or barrel limitations. What in the 'ell is different in chambering with a "worn out" machine with any chambering method? With a tight headstock and bearings, the ways are not an issue. Tailstock alignment is not an issue either.
    If you have chambered a barrel before and understand good machining practice, you will understand what I'm saying.
    If this PDF opens for you I believe it has 130+ pages about chambering. 130 page PDF of different chambering methods | Shooters' Forum
  14. Likes tdmidget, gbflyer liked this post
  15. #12
    Mar 2019
    ALAND ISLANDS
    33
    22
    13
    Quote Originally Posted by Butch Lambert View Post
    Thanks for the link and I certainly do appreciate the condescending chuckleChambering barrel. I saved that and printed it several years and barrels ago. Lots of good stuff. Please keep the helpful tips coming, plenty to learn yet.
    If you have success running through the headstock then please do so. As the PDF suggests, there are many ways to skin a cat. Iíve got a long, 1.30 diameter headstock...oddly enough a high tail stock and the quill runs about .002 out at full extension. I did build a spider for it. Old import Enterprise out of a prison workshopChambering barrel. Used an spare concrete slump cone for the sheet metal work. Thereís a thou to thou and a half play in the headstock bearings as best I can measure depending on if itís warmed up or not. Thatís about as worn out as I want to get working near the headstock, I prefer to spread the error out down to the other end but thatís just me. Iíve done 25Ē and longer barrels ďchuckedĒ in the headstock with this store bought spider I believe is intended for the other end. . Turned out to be a damned nice .35 Whelen even though I did have to mail it off to the lower United States for Cerakote :. No doubt theyíd all be in the same hole with better machining practices but thatís the best I can do at my current level.
    Iíve built pushers and even tried a Bald Eagle. Didnít like either much but the barrels still somehow shoot well. For my situation, between centers works best. I think that way is included in the 130+ pages?
    Hereís the last one I did, wrong handed again but it does shoot even though I cheated with a Borden action (makes even me look good). No glorious group pics for the bragging board, unfortunately it was still raining the day I put it on paper and ruined my target in the back of the truck before I got home. Dog ate my homework Chambering barrel.
    Wonder how the OP is coming along anyway...
  16. #13
    Oct 2002
    Poetry Texas USA
    1,802
    343
    235
    Well, we did get off topic.
  17. Likes gbflyer liked this post
