Chambering mishap, saved by the process
Likes Likes:  0
Results 1 to 3 of 3
    Nov 2004
    RC, CA
    2,197
    228
    473
    Default Chambering mishap, saved by the process
    Predrilled the chamber to the base to shoulder dimension of the cartridge. Didn't allow for the case head being clear of the barrel for the bolt c'bore, making it 1/8" too deep. Fortunately, I rough the shank and chamber a little deep before threading and finishing the shank to headspace dimension. That saved me the trouble of picking up the thread and extending it, or cutting a relief groove. Cost me an 1/8" of barrel length, but I think I can live with that.
    Picked up this method years ago from the writings of Jackie Schmidt. His reason made sense, being able to inspect the chamber before doing the easy stuff.
    Feb 2001
    Arizona
    2,331
    391
    Good idea. I will keep it in mind.
    Apr 2013
    Mercer Island WA
    75
    17
    When I drill the chamber, it is a short distance ~ 1/2" and the clean up with boring bar, and then the reamer.
    I want the pilot always engaged in the bore. After a the reamer has got the taper going, I can leave out the boring bar in each step.
