Color Hardening Questions
Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Apr 2020
    Idaho
    77
    19
    Default Color Hardening Questions
    Hey All
    Does anyone know if Turnbull or the other classic gun restorers anneal the various parts that are to be re-cased, or simply finish and then give them a second application? I never thought to ask the gunsmith that did my Win '76.
    Aug 2005
    Tucson AZ
    6,592
    10372
    3138
    It is not necessary to anneal to harden. The piece must be heated to the critical temperature and thus IS annealed. If this for color hardening then the previous colors may need to be buffed off
  3. Likes 4575wcf liked this post
    Apr 2020
    Idaho
    77
    19
    Excellent, clears that up, thank you. So then, there should be no harm in annealing a part in to order to repair it before the case hardening takes place. Correct?
    Aug 2005
    Tucson AZ
    6,592
    10372
    3138
    Correct. If the part was previously case hardened then any new added metal will not have the same amount of carbon or nitrides as the old and masking may be required to have the same case thickness through out.
    Dec 2012
    AUSTRALIA
    3,598
    15
    1249
    I d be a bit careful of whats actually going on.........most of the gun restorers do a "sub critical" colour.......bright colours ,but any actual hard case is softened by the process..........the beauty of sub critical is that there can be no shrinkage of parts ,which is a big risk with guns with long tangs ,which tend to shrink in actual high temperature colour case ,and no longer fit the wood.
    Apr 2020
    Idaho
    77
    19
    Okay I think I am following here. I am not familiar with "masking" and I am not familiar with "sub critical". I assume the first is a way to protect pre-colored parts to allow the soft ones to color the same, I assume sub critical is to harden at a lower temperature? Sorry, I am a long term machinist but very new to case coloring. Shrinkage would be no issue, I am building the wood and repairing or building nearly everything else as well.
    Dec 2012
    AUSTRALIA
    3,598
    15
    1249
    I just saying the restorers use sub critical colouring,because colour is whats wanted,and distortion cant be tolerated......if you want hardness ,then the best modern process is vacuum carburising.....but this leaves an even grey colour ,and somewhat shiny if the part was originally polished.......Incidentally ,for the hobby builder ,chrome moly steels dont satisfactorily carburize,which is why you dont see a 4110,or 4115 listed.
  9. #8
    Apr 2020
    Idaho
    77
    19
    I did a bit more research. It seems good colors without much hardening can be gotten around 1350 degrees. Very dark colors can be gotten at about 1500 degrees, and no colors at all at 1600 degrees. I think the suggested temperature of about 1450 is going to be the best compromise. I will be using a forge, so some means of controlling temperature must be thought up. For now I am just prepping parts, my first hardening try is still quite a ways off.
  10. #9
    Mar 2005
    Indiana
    5,344
    1662
    1572
    "Sub-critical" just means they are staying below the critical, or transition, temperature normally used for hardening that steel alloy.
    And 4*** series steels don't need to be case hardened, they have plenty of carbon. If you need a hard shell, you'd flame or induction harden those. For a very thin hardened layer you can actually do induction hardening underwater so you get an instant quench as you travel down the part like with flame hardening lathe ways. Not a simple process though...
  11. #10
    Aug 2011
    Oregon
    2,604
    602
    792
    I watched a video of Uberti CCH and the parts looked like quenching went in with the dullest visible red. Their colors seem good to me but it seems to me the best effect would be both a hard surface and good color.
  12. #11
    Jul 2020
    488
    176
    93
    I was trolling on this post, and could not stay out of it.
    all was said very much dead on,
    couple of questions?
    why re-case the parts?
    any time heat treat is involved & depending the type of steel, and heat treat parts distort badly.
  13. #12
    Sep 2018
    ALAND ISLANDS
    85
    35
    Quote Originally Posted by 4575wcf View Post
    Are you intending to stock the gun after you have it case colored? Inletting the stock can damage the finish of the metal. You're in and out of the wood a million times, tapping the action with mallets to transfer the inletting black. Not to mention you're shaping the outside of the stock and you'll have files and other abrasives near the metal finish.
    Pat Jones
    Firestone CO
  14. #13
    Apr 2020
    Idaho
    77
    19
    Hey All
    Thanks for the responses and keeping this thread alive a bit longer. I am building a field grade double on a stripped and rusty LC Smith FWT frame that I bought some months ago. I am finding and using rougher parts, since part of the fun for me is identifying and cleaning up useful goodies in parts lots. My goal is to not use parts that are so nice that they could be used to restore a fine original. They aren't making any more of these guns. I know six times more now about LC Smiths than I did six months ago, but I still have much to learn. I will assemble, troubleshoot, do the woodwork, finish the wood, case color, and rust blue in order. You can find my build on the Shotgun Forum in the High End Specialty Shotgun Forum. I am having a ball, and doing the write up to keep myself on task. So far I haven't attracted any similar builders to bounce plans and ideas off of.
  15. #14
    Dec 2012
    AUSTRALIA
    3,598
    15
    1249
    Strange things in the gun world.....stuff like high end doubles was gold a few years ago ,milsurps were common as dirt and priced accordingly........now everyone piling into milsurps ,prices have gone insanely stratospheric,and left the "best gun" collectors floundering........even old Winnies and Colts ,the longtime haven of the aged millionaire collector ,seem to have fallen by the wayside ,to some extent...........Strangely (or not) the biggest price jumps are seen in WW2 guns with Swastikas imprinted thereupon.....(Nazi proofs and marks)
  16. #15
    Apr 2011
    Nebraska
    1,357
    2145
    440
    Quote Originally Posted by john.k View Post
    I think a lot of the present interest in the surplus guns with nazi proof marks is the 75th anniversary of the end of WWII. Lot's of old war movies on TV, documentaries, etc.
    JMHO
    -Ron
  17. #16
    Apr 2020
    Idaho
    77
    19
    WWII stands out as the huge event of the 20th Century. You can study it for years and not get your head around it. The idea that a civilized modern world of 1940 could produce something like the Holocaust, well that is food for thought.
  18. #17
    Jul 2011
    Americus, Georgia
    452
    558
    135
    Here is a bit about temper color.
    Temper color forms when a steel is tempered or cooled in air or a mildly oxidizing atmosphere. The color ranges from straw to blue depending on the thickness of the oxide skin. The temper color versus temperature for carbon steels held at a certain temperature range for ten minutes or less is as follows.
    Color Temperature
    very faint straw 400*F
    faint straw gold 440
    straw gold 475
    bronze 515
    purple 540
    blue with purple tinge 640
    deep blue-gray 700
    300 series Stainless
    very light straw 700
    light straw 800
    straw 900
    dark straw 1000
    bronze 1100
    peacock 1200
    blue 1300
    light blue 1400
  19. #18
    Aug 2005
    Tucson AZ
    6,592
    10372
    3138
    "Tempering" and case hardening are vastly different things.
  20. Likes eKretz liked this post
  21. #19
    Apr 2020
    Idaho
    77
    19
    I would agree, but this might be useful. Could a bightly polished case box containing the parts be brought up to light blue in the forge and held just short of turning red for a few hours as a means of heat control?
  22. #20
    Mar 2005
    Indiana
    5,344
    1662
    1572
    If it was made of stainless maybe. I would much rather use a temperature controller...
