A curious way to rifle a barrel....
Results 1 to 11 of 11
    Dec 2013
    Vermont, USA
    447
    6
    110
    Default A curious way to rifle a barrel....
    I was watching a really cool YouTube video showing a restored vintage sine bar rifling machine in operation, and on a whim, searched "rifling machine" on ebay. No luck on chancing into a neglected but restorable sine bar machine near me at an afforadble price (or anywhere- yes, I knew this was daydream category, but stranger things have happened with other things that I have in fact bought and brought home).
    But I did find something that, if nothing else, may provide amusement - the apparent Ginsu Knife for would-be-rifle-ers-everywhere, the "Barrel Buttun Rifling Macchine" [spellings copied from original ad copy]
    Portable Barrel Rifling Machine for Button Rifling Process Push Chamber Reamer | eBay
    The only thing that I can figure is that spiralling formed on the button itself is supposed to actually cause the button to turn as it is shoved through the hole down the barrel?
    It slices, it dices, and it apparently even functions as a chamber reamer (though I am very unclear how). It probably even allows you to change your flat tire.
    I am disappointed to realize that this is unlikely to pose competitive threat to Douglas, Shilen, or any user aspiring to precision and accuracy... but it gets some credit for novelty...
    Aug 2010
    Minnesota
    1,943
    148
    1430
    Apr 2006
    vancouver b.c.
    45
    17
    I don't think it's for mass production. it's meant for people who live in countries with onerous gun
    restrictions who have to build their own.
    Sep 2018
    Washington
    8
    5
    The rifling machines I've seen in operation were built on a modified horizontal broaching machine.There was a system set up on the machine that turned the button at the rifling twist rate as the button was pulled thru the barrel.The same machine was also used for broaching barrels.Tooling was changed and a oil coolant setup installed.The change over from buttoning to broaching was done in a matter of minutes.I rather doubt the device on EBay would work.
    I believe I've seen rifling buttons on EBay as well.They were the push thru type instead of pull thru.The device on EBay should allow you to get a button stuck in the barrel blank though.
  5. Likes MIBill liked this post
    Jan 2016
    New York
    21
    15
    From what I see it's an attachment for a hydraulic jack that uses various rods to push a rifling button through a barrel. The concept is functional. But... and this a big but, the end result will be full of tool marks as the button is pushed one stroke of the jack... then stops. Then gets pushed again... and stops...
    The end result may look like rifling, but will be rough as a cob. Fouling is gonna be a major issue.
    Old school single point cut rifling would be a much better choice. JMHO, YMMV.
    Sep 2004
    NH
    1,116
    86
    I did watch some yt videos made by a guy who was known for his .50BMG rifles but can't think of his name right now. He was buying rifling buttons on ebay from both China and Europe and was successfully rifling barrels with a minimum amount of equipment. I don't have time to search for them now but they should be easily found.
    Dec 2012
    AUSTRALIA
    1,699
    7
    520
    Im sure a lot of the el cheapo barrels on the market are buttoned by simple pull without any powered rotation of the button save the tendency of the grooves formed to rotate the tool.........however ,rifling pitch variations are a well known fault in buttoned barrels causing mysterious inaccuracy,and name makers invest heavily in devices to detect this fault in the finished product.......I doubt any of this concerns the basement builder of illegal arms in Manchester or Leeds.,likely customers of the jacking device........incidentally, a workable chamber for say 9mmx19 can easily be swaged into a barrel,not really necessary anyway,because some sort of lathe is essential in the manufacture of the blank any way.
  9. #8
    Jul 2011
    Brusly, LA
    708
    20
    278
    Having been to shilen and watched the buttons pulled through the barrel, the press used to do it does not turn the button at all, the twist of the button causes the rotation.
    According to the techs there , the conformity of the hole drilled , then reamed, then honed in the barrel first is more important than the button pulling, then followed by the bore lapping after rifling. One additional step which is very important is the inspection process where the bArrels are inspected , graded, or rejected and re bored.
  10. #9
    Aug 2011
    Oregon
    2,501
    542
    740
    It works, but with "Staging" I expect. I use a powered hydraulic press that's limited to 14" of travel, which is plenty for pistols.
  11. #10
    Sep 2014
    UNITED KINGDOM
    11
    7
    I doubt rifling is high on the processes list either.
    Notwithstanding, it just proves mans ingenuity and the total waste of time some gun laws (anti-gun laws) are. If there are some things a person cannot get or have access to, they will just make one.
  12. #11
    Virginia
    25,617
    7561
    8058
    Quote Originally Posted by tenmetre View Post
    .. proves mans ingenuity and the total waste of time some gun laws (anti-gun laws) are. If there are some things a person cannot get or have access to, they will just make one.
    "Real Lawbreakers" probably settle for smoothbore, anyway. If they DIY at all. Few do.
    Whole lotta things, hulled, winged, wheeled, tracked, four legged, two-legged, belly-crawler or finny-fish been kilt with smoothbores over a longish history, bombards through Carronades to tank main guns, or muskets to shotguns.
