I machined a 10/22 blue barrel for a two point mounted suppressor(form1). The last two inches of the barrel werre turned down to .485", with 9/16-18 threads on the rear part of the machined portion. I finished by cutting an 11 degree crown onto the muzzle. This is the first crown I have cut. I had slight chattering problems. The cutting tool was mounted in a tailpiece chuck and the barrel turned at 180 rpm (my slowest ), while using a steady rest.
My problem is that accuracy, while never great (3/4" at 25 yards) has degraded by about 25%. I think it is the crown I put on causing this. Do I need to "shoot in" the new crown? Does a cutting tool tend to push metal up and into the bore? Is there a way to stone the muzzle to prevent this? Would a flat crown followed by some stoning work better even if it leaves the edge of the rifling exposed? Thanks.
Ranb
Ranb
