D Reamers
Likes Likes:  0
Results 1 to 3 of 3
Thread: D Reamers
    Nov 2003
    Palmer, AK, Usa
    11
    Anyone ever tried a D reamer? I made one yesterday in 6.5/55. Used O 1 made a blank that fit the chamber of my 94 swede then milled half of it away, then hand hone the cutting edge, harden, grind a small releif on the belt sander. I am amazed at how good it cuts. It moved the chamber forward on the swede 1/4 inch easily. I musta got lucky on my first reamer. I also used a full length resized case to check my work, it seems to fit good. Haven't fired it yet. Jon
    Oct 2001
    Montrose Iowa
    1,180
    Here a link to another sight that talked about them http://www.chaski.com/ubb/showflat.p...sb=5&o=&fpart=
    Mar 2001
    alvaton,ky
    981
    7
    34
    1/2 reamers work fine ...i used them for piloted centering reamers w/out any relief..& also whenever i need a specific size .the problem IS warpage ....if they are halved before hardening ,there is a tendency to warp right there ....i keep a banana 30 -35 stevens 1/2 reamer around to remind me .....vertical quench in 200 rpm drill press helps ....but eeven my O1 fluted reamers will run out .008 to .010& need grinding ......wud just as soon make fluted ones.......if u make ur roughers .010 or less under , u can usually polish out enuf to make a f. l. resizer ( for yourself at least)
    best wishes
    docn8as
