John, Sorry I didn't see your replies earlier. I'm not able to take on any more work just now.
On making a dent raiser: Here's a video by Larry Potterfield of Midway USA that very quickly runs through what is going on with a dent raiser:
https://www.youtube.com/watch?v=xQB3kfl_a0g
I don't use steel for the sliding wedges on mine, I use brass. Also, I tend to use a steel hammer on the outside of the barrel, not brass. This is sort of an odd inversion of what you see Mr. Potterfield doing, but my theory is that I don't want to put something down the bore that might cause me to have to hone out a mark, and steel-on-steel is apt to scratch the bores.
The hammer for the outside: I use a very small 4 oz. ball pien hammer, which you can find most anywhere, but I've polished the face and the ball to about 800 to 1000 grit levels - they're not quite a mirror finish, but they're close. I find that using a highly polished face on the hammer means that the blueing is left as little disturbed as possible, and I'm not putting more marks into the exterior steel that I must polish out when I'm done.
I can't demonstrate the technique here online, but I wish to emphasize in the strongest possible terms that you aren't using heavy blows from the hammer at all - it's more like a gentle tap-tap-tap, stand back and observe carefully, then a bit more tapping, etc. After a bit of tapping, I might re-position or re-tension the dent raiser. Another thing to emphasize is that the raiser is sort of mis-named. Beginners think that the raiser is used to raise the dent directly. Well, no, it isn't. The "raiser" is merely a backing anvil which you use to "jack up" the area surrounding the dent, and this surrounding area is that you lower the steel surrounding the dent, then you even things up. It's difficult to describe with just words, it becomes very clear the first time you see it done in stages and you run your hands over the barrel as you're doing it.
Proceed with deliberate, slow action. Don't over-tension the raiser on the first application of the hammer - you want to position the raiser completely under the dent, then tension it to be snug and a little bit more, then start tapping. After you're making a little bit of progress, check the tension on the raiser.
Most shotgun barrels are rather soft as well as thin - some fine guns might have barrels only .025 to .030 thick in the middle area between the chokes and forcing cone. Many American guns will have barrels that start in the .040+ range, but might have been honed out over the years to remove pitting. I always check the wall thickness of shotgun barrels before I do anything radical to them, as well as run a bore gage down them to find out what the barrel profile looks like.
