Denver barrel threading
Results 1 to 14 of 14
    Nov 2015
    Colorado
    7
    Default Denver barrel threading
    Ive been researching what lathe to look at to perform my own gunsmithing, but came across a thread on here about cost of having a barrel threaded. I have 5 rifles Id like to add muzzle brakes to but after finding that thread, its obvious that Id never make the ROI work for my personal use unless I took outside work.
    So on that note, Id rather give my business to a PM member. Anyone in the Denver area that is as OCD as me to get the job done right?
    Aug 2015
    Illinois
    1,135
    831
    478
    I threaded my barrels on a 14x30 lathe. I used a brass muzzle protector supported by a live center. Grizzly sells the muzzle protectors but you can make your own. I left the receiver on the barrel. I put a steel bar where the bolt would be. I held the receiver in the 4 jaw and indicated on the barrel just ahead of the receiver ring to get it running true. Then I machined the threads. The only real requirement for the lathe was the bed needed to be long enough to hold the barrel and receiver.
    The lathes sold as gunsmith lathes have a big enough spindle hole to let the barrel pass through and a short enough headstock to let barrel stick out the back so it can be centered in a spider.
    A lot of barrels have been threaded and chambered with the muzzle end held in a chuck and the breech end supported by a steady rest. In other words you do not need a special lathe for gunsmithing. You just need a bed long enough to accomodate your work.
    Oct 2010
    Dewees Texas
    2,046
    25
    519
    I think the OP is asking for a Practical Machinist member in Colorado to do the work for him. Given the trouble of buying a lathe and building the attachments to do barrel work and learning the skills, I think that is a wise move.
    If I am right in my understanding of the post, give him a hand. Driving a couple hundred miles to bring the work to you has to be a lot easier than buying a lathe, picking it up, finding space, wiring it, building cats heads, and the doing the learning curve.
    Even if he did all these things and did the work skillfully, jumping all the hoops to legally do the work for someone else to use his new found skills would be another mountain to climb.
    Jun 2016
    New York
    1,145
    530
    486
    OP shouldn't have to drive that far, lots of excellent 'smiths on the front range.
    T,find the bench rest crowd and ask them for a recommendation if you are looking for some truly OCD work.
    Jun 2014
    Floral City, Florida
    12
    I've threaded barrels without a lathe before, slower and more work but comes out fine. If you are only doing five and have no need for a lathe beyond that, have someone else do them. Barrels are easy and relatively inexpensive to ship if you can't find local.
    Jeff
    Sent from my XT1254 using Tapatalk
    Jan 2008
    Mountains of Washington State, USA
    430
    130
    Quote Originally Posted by TruckinT View Post
    I’ve been researching what lathe to look at to perform my own gunsmithing, but came across a thread on here about cost of having a barrel threaded. I have 5 rifles I’d like to add muzzle brakes to but after finding that thread, it’s obvious that I’d never make the ROI work for my personal use unless I took outside work.
    So on that note, I’d rather give my business to a PM member. Anyone in the Denver area that is as OCD as me to get the job done right?
    Go to 24hourcampfire, hit the gunsmithing area, ask for gunsmiths in CO.
    Nov 2015
    Colorado
    7
    Quote Originally Posted by FredC View Post
    Exactly what I'm looking for. I'd have some use for it outside of gunsmithing, but not enough to justify the purchase, learning curve, etc. like you mentioned.
    Quote Originally Posted by cyanidekid View Post
    Great idea, maybe I can find a long range competition or something and pick their brains.
    Quote Originally Posted by SilveradoHauler View Post
    Thanks for the insight, I'll head there and see what pops up.
    Thank you all for your help!
    Oct 2004
    Montana
    1,022
    25
    40
    Dan Dowling is somewhere Denver and is very good.
    GraTan is in eastern Colo., also very good.
  9. Likes TruckinT liked this post
  10. #9
    Nov 2006
    Greenwood, Ca
    922
    44
    274
    What type of rifles?
  11. #10
    Nov 2015
    Colorado
    7
    Quote Originally Posted by 300sniper View Post
    2 AR’s
    2 300 Weatherbys
    1 6.5 Creedmoor
  12. #11
    Feb 2001
    Arizona
    2,147
    290
    Default Receivers?
    What brands of receivers?
  13. #12
    Nov 2015
    Colorado
    7
    Quote Originally Posted by GGaskill View Post
    Both AR's are Aero Precision uppers and lowers, A15 lowers, don't recall the model of uppers.
    Weatherby Mark V Accumark with a fluted barrel in 300 Wby Mag.
    Weatherby Mark V Standard in 300 Wby Mag.
    Howa Kuiu Vias in 6.5 Creedmoor.
  14. #13
    Sep 2018
    Mile High does most of my threading. They cut the prettiest threads I've seen on my Accuracy International AX 260 barrel. Gunsmithing
  15. Likes TruckinT liked this post
  16. #14
    Oct 2002
    Poetry Texas USA
    1,691
    207
    177
    Well, some not OCD suggestions on here. You can't indicate the OD of a barrel and expect a quality job, and especially by hand. I have found USPS to anyplace in the CONUS is a lot cheaper than fuel from one side of Denver and then another trip to pick them up when completed.
    If you want a Colorado guy, that is one of the best, search Dan Dowling. He is great, but doesn't put up with BS. I've known and shot with Dan for over 25yrs.
