Difference in chambering a 5R barrel
Results 1 to 11 of 11
    Feb 2011
    Northern CA
    17
    7
    Default Difference in chambering a 5R barrel
    I’ve read that when chambering a 5R barrel there can be a greater chance of developing chatter. Is there any truth to that or do you guys do anything different to help avoid this?
    Mar 2006
    New Jersey
    1,175
    15
    372
    Yes,there is a greater chance at chatter. I think this is due to the odd number of lands vs the even number of flutes on the reamer not cutting all at the same time.. I find that if I drill and pre-bore as much of the chamber as possible, I can avoid these issues. This leaves the reamer fully supported and with a good tight fitting bushing, the throught should not be an issue. Others will chime in with their theories and solutions. Everyone has different equipment and methods of cutting chambers, so there is no single solution. Different bore diameters and chamber sizes will also give different results.You have to experiment and see what works best for you.
  3. Likes Colt45, Butch Lambert liked this post
    Jun 2007
    OK
    276
    8
    41
    Yes it is true and I've had a couple that chattered no matter what I did, pre drill, bore, etc. Probably aggravated with smaller calibers as the reamer can flex more in the throat area.
    Nov 2006
    Greenwood, Ca
    981
    52
    330
    I personally haven’t noticed any difference.
  6. Likes Lharmon liked this post
  7. #5
    Dec 2007
    175
    23
    20
    If lands and grooves are causing chatter you have other problems. D
  8. Likes 300sniper, tdmidget, Lharmon liked this post
  9. #6
    Aug 2004
    Centerville,OH
    2,173
    97
    I've done several 54r barrels and have never experienced chatter. First time I've heard of it being an issue.
  10. #7
    Jun 2007
    OK
    276
    8
    41
    Believe it or not....I didn't. Obermyer barrels btw.
  11. #8
    Feb 2011
    Northern CA
    17
    7
    Thanks for the replies on this. I was curious how prevalent this was, some people say it can be a problem and others have never noticed any difference. The reading I have done on it suggests something to do with a 6 flute reamer and a 5 land barrel.
  12. #9
    Sep 2018
    ALAND ISLANDS
    96
    40
    Quote Originally Posted by Bryan M View Post
    Most cut rifle barrels have 5 flutes
    Pat Jones
    Firestone CO
  13. #10
    Dec 2012
    St. Louis, MO
    347
    29
    83
    Just to add a datum; I've never noticed any difference chambering any variant, 4, 5, or 6 groove.
  14. #11
    Oct 2002
    Poetry Texas USA
    1,948
    620
    297
    I've only done a couple Obermyers and no trouble.
