Greetings gents,
I'm in the process of building a sporter Moisin Nagant rifle, the base was a Polish M-44. The stock is a nice piece of American Walnut, care of Boyds. All metal work has been done by me, bent bolt handle, relocated to the rear, bayonet and front sight removed, and replaced with a slimline muzzle brake of my own design.
Now to the source of my angst.... I did not want to inlet the stock where the rear sight bracket was mounted, and want this thing to be a scope only rifle. Thus, I want to make a custom scope base that will go from the ejection port to forward most area of where the rear sight was mounted. I have several different ideas as to how to go about this, first is a piece of round stock drilled and bored on the lathe to match the contours, then milled into a suitable scope base. That's a LOT of work! Next idea is to take a piece of bar stock, mount it vertically on an angle plate, and use a long boring bar in a boring head to duplicate the contours. however, that's not going to be the greatest as I'll still have a significant amount of hand fitting left due to not being smart enough to create the slight tapers necessary.....
Does anyone have any other ideas???
Ken
Ken
