tenmetre
- Sep 21, 2014
- United Kingdom
I am considering "Magnaporting" one of my pistols.
Now, before anyone suggests I "just send it off" that is quite simply not possible. Either I do the work on my guns or it doesn't happen.
The gun in question is a Ruger Super Redhawk in .357 magnum, all stainless with a barrel length of 10.5", 12.25" from the rear face of the cylinder.
I was thinking four "holes" at 35 degrees from the vertical and 5 degrees rearward on either side at the muzzle. I know that Magnaport use EDM to cut the barrels, I don't have access to an EDM setup.
I thought I might fill the end of the barrel with woods metal in order to reduce any issues with any burrs that may be formed.
I would welcome your comments or suggestions before I set out.
