Ronniet
- Feb 21, 2011
- Amarillo Texas
OK , I need some advise,
I have this beautiful very slim type Maple Mannlicher stock that someone custom made. Its flawless, mated to an early Sako barreled action.
Its only flaw was the use of a Winchester model 94 barrel band at the mid point of the forend.
It fit OK but had no business being on a Mannlicher stock and although the barrel channel was completely glassed it is not free floated and the barrel band just adds to its rigidness.
I have thought and thought about how to correct this injustice.
I decided to make a Sling stirrup and place it at this junction to help with the 2 screw holes that were used for the barrel band because the checkering is accented on each side of the band and that way I can do away with all traces of the barrel band and open up the barrel channel to float its barrel.
Ok my build on the stirrup as I have done so in the past is to use a 7/32 4140 welding rod for the stirrup and and bend 2 90s on it that just missies the edges of the wood but only After I heat and flatten and shape the 2 endos of the stirrup on to drill for a 6x32 oval headed screw and the other end to be tapped for the screw. but my problem is this
The 2 holes in the sides of the forend are of 2 different sizes of wood screws which only barley miss the glassed barrel channel.
But I need to enlarge the holes but only on the bottom part of the holes ( to miss the barrel channel)and it needs to be straight across the stock forend as to end up at the other hole, right now they are blind screw holes, and I need to enlarge them for a steel tube to be installed to be glassed in just proud of the wood to give the sling the desired swing and keep from pinching the wood.
So is there a jig or tool I could fabricate that would allow me to drill such an accurate hole and get it where it just clears the top part of the larger hole.
Or maybe just get a couple slugs or Crown Royal and my Craftsman cordless drill and my best bit and have at it?
Ron
Ron
