Enlarge 224 to 308 for piloted countebore?
Results 1 to 10 of 10
    Aug 2012
    Canada
    136
    78
    18
    Default Enlarge 224 to 308 for piloted countebore?
    Is it at all practical to consider enlarging the initial section of a 224 bore (say 219 actual) to 308 (.300) so that I can use a piloted counter bore that I already own (made for .300)? If so, what would be the best way to do it accurately?
    After its all done, that section of bore get oblitered when I predrill it and use a boring bar to straighten it. So it does no harm as far as I can see to bore it out to .300 to allow the piloted counterbore to be used. But how to do it reasonably accurately?
    (EDIT: This is all work at the muzzle using a PTG bolt nose counterbore
    .705 Counterbore Without Step - Pacific Tool and Gauge
    made for roughly .300 and up pilots)
    Oct 2002
    Poetry Texas USA
    1,733
    278
    193
    Quote Originally Posted by Grizzlypeg View Post
    So you have no way to single point to cut it? I see no problem if you cut that part of the muzzle off or bore and make a recessed crown.
    Aug 2012
    Canada
    136
    78
    18
    I could single point cut the bolt nose recess that this counterbore makes, but it worked so slick on my 308 that I would like to use it on my 223, but of course the pilot is too large. This particular brand, PTG doesn't permit a pilot for .223 to be used on it. I think it only goes down to .300. So if I could see a way to make the .219 bore opened up to .300, even if it lost .001 concentricity in the process, I could use the counterbore tool. My apologies if I am misnaming this tool. Its a piloted tool that makes the .705 for a Remington bolt nose at the breach.
    Sep 2018
    35
    15
    I just cut my counterbores with a boring bar, usually after the chamber is nearly complete. If you chamber first, there's not much left to cut.
    Sent from my Pixel 2 using Tapatalk
  5. Likes Butch Lambert, Grizzlypeg liked this post
    Oct 2002
    Poetry Texas USA
    1,733
    278
    193
    I do as Pat does his.
    Jun 2008
    TN
    1,532
    313
    247
    Same here.
  8. Likes Butch Lambert liked this post
  9. #7
    Oct 2002
    Poetry Texas USA
    1,733
    278
    193
    Quote Originally Posted by henrya View Post
    Same here.
    How is life treating you? Long time no see.
  10. #8
    Aug 2012
    Canada
    136
    78
    18
    Thanks for the good practical advice. I will take it.
  11. #9
    Jun 2008
    TN
    1,532
    313
    247
    Quote Originally Posted by Butch Lambert View Post
    All is well. We have a new range up here that just got opened in February. I may start shooting UBR with them. How about you?
  12. #10
    Sep 2015
    Florida
    535
    72
    Dave Manson makes the counterbore tool with a #1 spindle for .22 cal.
    What else should we spend our money on, but more tooling?
    Besides, boring to within a thou just ain't in my skill set. The form cutter faces the barrel end and puts a radius on the counterbore entrance.
    Time is $$, the tool makes it fast, and perfect.
