ETD150 Steel
Results 1 to 12 of 12
Thread: ETD150 Steel
    Sep 2019
    Maryland
    Default ETD150 Steel
    On McMaster Carr its listed as 'high strength 4140' would this steel be a suitable option for a barrel steel? 130k psi yield is a very attractive number, but I am wondering if there is a catch.....anyone have any experience with etd150?
    Dec 2012
    AUSTRALIA
    2,107
    9
    634
    never heard of it.....but 4140 is a common barrel steel...anyway,what you quote seems to be 4140HT to me.
    Nov 2007
    marysville ohio
    9,364
    2673
    6188
    Quote Originally Posted by sargentcrunch View Post
    It is great stuff for studs and shafts and such. The studs that hold the engine on the back of the tub on an Indy Car are made of it. In a huge crash I have seen a 3/8" stud stretch an inch before failure.
    Jan 2013
    Plainfield, Indiana, USA
    1,739
    1315
    926
    Elevated Temperature Drawn (ETD) 4150. Stronger version of 4140 or 4150, works about the same.
    Nov 2004
    RC, CA
    1,973
    211
    376
    'Elevated temperature drawn' raises a red flag for me. Same process, I believe, used to make 'Stressproof', and it's generally not considered to be suitable for high pressure barrels.
    For a blackpowder barrel you might be fine. Otherwise, I'd be checking with the manufacturer, NOT a supplier, as to its suitability.
  6. Likes Matt_Maguire liked this post
    Feb 2001
    Redwood City, CA USA
    4,969
    179
    904
    ETD-150 is resulfurized to improve machinability. This may reduce fracture toughness and impact toughness in particular. Check with the LaSalle, the manufacturer. ETD-150 is lovely stuff for things like tailstock quills, but I am not so sure about gun barrels.
  8. Likes Illinoyance liked this post
  9. #7
    Sep 2019
    Maryland
    This would be for a .44 magnum single shot, I sent an email to LaSalle to see what they say. Though I imagine as soon as they hear 'gun barrel' they will refuse to comment haha
  10. #8
    Nov 2004
    RC, CA
    1,973
    211
    376
    416 stainless is commonly used for barrels. Also a resulphurized material.
    However, barrels are made from 416R, designating rifle barrel quality. Not necessarily the same as generic material you'd get from industrial suppliers.
    Levels of sulphur, and sulphide stringers are controlled.
    'Transverse Rupture Strength' is a property that comes to mind. And I think stringers are a bad thing in that regard.
    I've seen no suppliers of it available from stock. Appears to be available only from the mill in larger than hobbiest qty requirements.
  11. #9
    Apr 2007
    Pillager, MN
    5,736
    1869
    5234
    Stop........................Why use a material that NO ONE else uses for barrels?
    Not suitable for high pressure spikes. Likes to crack.
  12. #10
    Mar 2006
    New Jersey
    1,088
    13
    297
    The other major barrel steel is 4140. Just use one of the two materials that every barrel manufactures use.
  13. #11
    Mar 2013
    Washington
    287
    137
    197
    I like etd 150 it machines nice but it WILL move as you work it
    I recently made a new cross slide lead screw out of it and it moved about .030 after threading 20190913_064801.jpg
    I would not use it for anything that you want to be straight after machining
  14. Likes partsproduction liked this post
  15. #12
    Dec 2014
    Minnesota
    56
    27
    Hi:
    It is my humble understanding 4140 and 4140 firearm steel are not the same (ditto 416 and 416R). There is a lot higher quality control and testing for any steel used in firearms to assure consistent structure throughout the steel bar. A flaw in a rifle action or barrel can and has killed people. You can get buy with different steels a lot of times but it only takes blowing up a rifle once to make a big impression (I have gotten by twice with only minor inquiry). I will also add that a lot of firearms have been made from other steels and aluminum but usually they are heat treated and tested to high standards (not including war production by countries who placed a low value on soldiers. Cast iron and bronze/brass has also been used in many low pressure firearms but it would not be my first choice. Just food for thought. GeorgeM
    PS: It is a lot easier to re-drill and rifle an old rifle barrel. There are lots of old barrels floating around. Just find a high power shooter he should have several.
