heckinohio
- Aug 25, 2009
- Ohio, USA
This is a Century rifle, came in as a machine gun, lost its receiver in customs. Century had semi auto version receivers made......somewhere. Material looks like cast stainless alloy to me. Pictures show what the problem is, bullet tip stops in two .040x.040 channels that may go all the way to the receiver front, parallel to the bores axis. I ground the ramps you see. Not practical to grind any farther, I am into the rear of the chamber now. If the little channel does go all the way to the receiver front, further grinding wouldnt help anyway.
Need to fill the little square holes........??? How.??
PJH
First stoppage, in the field, nothing ground yet.
Bullet tip jammed in .040x.040 channel end.
Same situation, other side.
PJH
