Firing pin steel
Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Feb 2009
    ireland
    462
    242
    221
    Default Firing pin steel
    I need to make some firing pins for my old sidelock shotgun. I was going to use silver steel (o1), but what do you all normally use for firing pins ?
    Dec 2008
    Vt USA
    8,900
    1477
    3154
    Quote Originally Posted by ronan View Post
    We in the US of A have a generic "drill rod" steel that I would not hesitate to use. Good for just about any critical application with proper heat treat.
    I think it might be the same a "silver steel" ;-)
  3. Likes ronan liked this post
    Jul 2018
    Wisconsin
    266
    73
    191
    Is this drill rod the same as drill bits are made from?
    If so, a hardware store twist drill could be selected of the appropriate size, cut or ground to the correct size and heat treated to reduce brittleness. (I may need to do this in the future.)
  5. Likes ronan liked this post
  6. #4
    Aug 2005
    Tucson AZ
    6,624
    10485
    3162
    Quote Originally Posted by Kurt Learning View Post
    You want a firing pin with twisted flutes? If you are thinking of the the non twisted shank, it is not hardened and usually not the high speed steel of the cutting edges.
  7. Likes ronan liked this post
  8. #5
    Feb 2004
    Traverse City, MI
    3,396
    149
    150
    Drill rod is a good choice. As a youth I made replacement firing pins for some single shot, shotguns out of just plan bolts. That was fifty years ago and they are still working. If the firing pin is hard to replace or a difficult to make design be sure to use drill rod and not just any steel that happens to be laying around.
  9. Likes ronan liked this post
  10. #6
    Oct 2010
    Dewees Texas
    2,898
    30
    897
    Hardware store quality twist drills are almost always high speed steel. With an unknown alloy, heat treatment would be problematic. Drill rod may have been used to make tool steel drills a hundred years ago, the name stuck but most drills made since high speed steel came on the scene are made from the new stuff. Any of the tool steels would probably work since firing pins are draw back so far. If you needed extreme toughness at 58RC L6 would be hard to beat It is just harder to find and unnecessary for firing pins at moderate hardness.
    To the OP O1 would be as good as any, I do not keep any in stock and would use W1 just because I have a lot of it laying around. If I was worried about toughness with W1 in small sections parts could be oil quenched instead of water quenched and be just fine. W1 is cheap enough to keep a lot of sizes in stock for just about any need.
  11. Likes ronan liked this post
  12. #7
    Feb 2009
    ireland
    462
    242
    221
    Yeah drill rod is o1. I normally use it to make leaf springs etc. Thats what i will use so.
  13. Likes BT Fabrication liked this post
  14. #8
    Oct 2010
    Dewees Texas
    2,898
    30
    897
    In hot rod drag/street racing there used to be a term "run what your brung". If it is a known tool steel and you have the heat treat specs it will probably work for you.
    On "drill rod" I think of any of medium to high carbon "tool steels" W1 included. A lot of them are available drill gauge sizes in 3 foot lengths. All of them centerless ground to fairly good tolerances with a good finish. Generic term but today a drill would be one of the last things you would make from them. I have made a couple of special taps from W1 though.
  15. Likes ronan liked this post
  16. #9
    Feb 2009
    ireland
    462
    242
    221
    I have lengths of o1, drill rod as its called on the other side of the Atlantic, that i will use for the pins. Its steel i use a lot of for various bits and bobs.
    I suppose its a nervous time for you lads who are gun owners and enthusiasts in the USA ? If it gets the same over there as it is over here, you're screwed.
  17. Likes Rick Hand liked this post
  18. #10
    Nov 2011
    Missouri, USA
    2,153
    1369
    2746
    It's all hot air. We lose more ground when Republicans are in charge, than Democrats, in my lifetime. Anti-gunners wouldn't have an evil opponent to help them raise money if they suddenly woke up and they got their way. So they will always be a bit self-sabotaging in order to maintain "job security" *eyeroll
    Plus, seems like some of the more liberal side is starting to see why our 2A in the Bill of Rights was made, in the first place, after their reaction to recent events. (some, not nearly all)
    ANYWAY
    I'd say any of the common tool steels would be fine, O1 being forgiving and easier to handle on ones own... especially if this isn't something you're gonna be putting another 10 thousand rounds through- I would almost say 4140 PH might be fine. Keep in mind that primer cup is typically brass/copper.
    If you're looking to maximize longevity, then I'd worry more about the particulars and finer details such as using a hardened tool steel with appropriate draw. If it's an old side-lock, I assumed it was a sporting gun, not necessarily a competition trap/skeet shooter that sees uber high round count through her. Forgive me if I'm assuming too much.
  19. Likes ronan, TeachMePlease liked this post
  20. #11
    Jul 2018
    Wisconsin
    266
    73
    191
    Thanks all for helping me understand that drill bits are not made from drill rod.
  21. Likes CalG liked this post
  22. #12
    Sep 2004
    NH
    1,181
    110
    I have made a few from allen or hex key wrenches. Not sure what the alloy is but it's tough stuff and so far no complaints.
  23. Likes sealark37, ronan, Kurt Learning, CalG liked this post
  24. #13
    Nov 2010
    upper southwest Arkansas,USA
    171
    52
    24
    It's a firing pin. No need for anything too special. Really good ones can be made from grade 8 bolts of the appropriate size. They are already hard enough and tough enough for a proper firing pin.
  25. Likes Kurt Learning, ronan liked this post
  26. #14
    Jan 2015
    Missouri
    1,316
    223
    838
    S-7 and be done with it
    Don
  27. Likes ronan, Winterfalke liked this post
  28. #15
    Dec 2019
    AUSTRALIA
    52
    8
    I made a firing pin for a hammer shotgun when I was about 14 using some spring steel from torsion spring off a car boot. Just heated to straw and quenched in oil.
    Made another one for a pump Action 22 that had a flat blade style firing pin. Used a thin file ground the surface and to profile and again heated to straw and oil quenched. Both work fine and I had absolutely zero knowledge or access to known materials or advanced heat treat.
  29. #16
    Dec 2012
    AUSTRALIA
    3,845
    18
    1350
    Cheap available source is old screwdrivers .....when the points are worn ,we generally just buy new..... many screwdrivers are marked "chrome vanadium"...these are the ones I use for gun parts.....The plain ones are high carbon steel ,also very suitable for pins ,pivots ,retainers etc.
  30. Likes Kurt Learning, 1yesca liked this post
  31. #17
    Sep 2013
    Michigan
    266
    96
    154
    I make custom bolt handles essentially exclusively from grade 8 bolts. They work flawlessly, are cheap, and Weld/machine easily. I have made a bunch of “Cut down” Mauser firing pins from O-1, after the titanium stuff stopped being available all of which seem to still work AFAIK.
  32. #18
    Nov 2012
    Michigan
    623
    216
    185
    1144 stress-proof (fatigueproof). It EXACTLY the type of application the alloy was made for!
    McMaster-Carr
  33. #19
    Apr 2005
    Beaverdam, Virginia
    9,641
    1342
    5002
    I make 10's of thousands of them a year for various customers. It seems A2 is the most common material of choice.
  34. #20
    Jul 2018
    Wisconsin
    266
    73
    191
    Quote Originally Posted by jonok View Post
    What do you mean by a "cut down" firing pin?
