Flexane Bedding
Likes Likes:  0
Results 1 to 9 of 9
Thread: Flexane Bedding
    Feb 2002
    Albany, OR 97321
    485
    20
    Kurt, Flexane is really rubbery to be bedding with. Do you intend to use additives, or are you trying for that micro-moment rail gun effect? GsT
    Feb 2002
    Albany, OR 97321
    485
    20
    test - wanna see if this will post.
    Oct 2001
    Montrose Iowa
    1,180
    Well Gene T, I do a lot of rimfires, and they are very vibration sensative, on one I used silicone, between the action and beding with good resulits for a wile. Browning uses some hard rubber like thing for the recoil area in there A bolts, just a though.
    Feb 2002
    Albany, OR 97321
    485
    20
    Have you seen the book 'Rifle Accuracy Facts'? There's some great research (as opposed to speculation) in there about vibration damping. The laminated flexural beams intrigue me. Flexane may achieve the same thing in a rimfire. If you try it, please post your results. Thanks, GsT
    Oct 2001
    Montrose Iowa
    1,180
    Yep Gene got the book, the laminating of the beams, and the cuts in the action, to hold them, seams to me, to be a PIA.
    Apr 2002
    Kaneone, HI
    46
    Gene I just got a flyer from Sinclair that has information on a CG Millennium Rifle action. It has a optional H&H Flexibed system. Looks like a aluminum bedding block with two linear elastomer strips set up inside. If you need more information, I could fax the brochure to you. Or you could check their wibsite: www.sinclairintl.com. Ph#260-493-1858.
    Feb 2002
    Albany, OR 97321
    485
    20
    Thanks Wayne. I have the brochure as well, I guess I just didn't look at it that closely. (A Sinclair catalog and myself are a financially dangerous combination ) I'll check it out. If you've never dealt with them, the folks at Sinclair are first rate - probably the best company, in any field, that I have done business with. (No affiliation, just a thoroughly satisfied customer.)
    May 2004
    Mission,.B.C., Canada
    8
    I'm cleaning up and rebedding my old (1966) Anschütz .22 sporter.
    I wonder how much flex is desirable? It might depend on the weight of the barrel. I'm not familiar with Flexane and hadn't thought of silicone, but just a crazy thought.... Permatex non-hardening gasket material??
    Oct 2001
    Montrose Iowa
    1,180
    Stuart I did not use much, just a verry thin coating. PS it didn't last long.
