Gear set for M13x1
Likes Likes:  0
Results 1 to 9 of 9
    Apr 2019
    Washington
    Default Gear set for M13x1
    I have an older Atlas craftsman 10127440 and am wanting to thread M13x1. The question i have is what gear combo do i need or how do i figure this out?
    I know i need a 127 and 100 to convert the sae lead screw to metric.
    Thanks in advance
    Jan 2006
    482
    55
    You need to ask this question here: General
    RWO
    Dec 2012
    AUSTRALIA
    2,585
    10
    803
    Thinkee Atlas Craftsman is a bit of a no no over there.Im thinkee a hobby machining forum with a dedicated Craftsman spot might be less traumatic to the OP.............incidentally ,any old machining book will have a formula for calculating any lead ,and in this day and age ,we wont make mistakes with the arithmetic ,cause we will use a calculator.
    Jul 2004
    Houston, TX USA
    30,446
    You'd jump way ahead on viability of your threads at Practical Machinist if you omit the A and C word as to make of lathe
    If you know you need the 1.27 : 1 compound, then a tiny bit of math will show you that 20 TPI (which is .050" lead) gets you a.03937" lead which is ONE MM for your M13
    To show the simple math:
    .050 / 1.27 = .03937
    And by extension... 10 TPI gets you 2mm and 40 TPI gets you a half a mm....among others
    Dec 2010
    Mifflintown, PA 17059
    1,808
    20
    212
    If you look in the machinist handbook it will give the formulas to calculate any metric or inch threads on any lathe.
    Nov 2004
    RC, CA
    1,985
    211
    380
    A more reasonable sized set of gears to get you close enough. There's another that is very close as well.
    Metric Threading
    Sep 2010
    moscow,ohio
    6,073
    592
    1964
    hell, if it's a short thread work out the lead for say,24 or 26tpi...
    Feb 2001
    Arizona
    2,218
    353
    1 mm pitch is 25.4 TPI so 25 TPI would be better if your machine will do it.
    Sep 2010
    moscow,ohio
    6,073
    592
    1964
    since the Atlas gearbox includes 30tpi you can use 52/44 in place of the 48/48 gear set to have all the common metric pitches.
    sacifices only the coarsest range of threads and is cheap an easy...slide a gear and adjust banjo.
    there is an explanation on the lathes uk site.
