german cut rifling machine
Likes Likes:  0
Results 1 to 5 of 5
    Dec 2003
    Calgary, Alberta, Canada
    1,415
    7
    96
    Default german cut rifling machine
    here is a link to a German custom gunsmith shop with a video of a cut rifling machine,
    http://www.max-ern.com/english/laufziehen.htm
    May 2006
    York, PA
    148
    An interesting design. Two things observed:
    The barrel(s) turn while the rifling cutter/broach does not. And there is a "needle" (nadle) that causes the broach to extend out of a sleeve to cut on the pull stroke only. On the return stroke the needle extends out of the sleeve, the cutter retracts and then the sleeve goes back through the barrel.
    The oil drip catches the cutter on both ends of the stroke.
    And it is all mechanical.
    Nov 2008
    AB Canada
    Being from Calgary you would know Ron Smith and this is not a lot differnt then his other then this one automatic indexes and the the back end turns the cutter as pulls it through.. Where as he pulls his through by hand..
    It would appear as though this one would have to have a fixed twist because its a geared head and Rons you can do gain twist if you desire being a cable drive.
    very interesting video thnx for adding it..
    SST
    Sep 2007
    Spanish Springs, NV
    2,365
    155
    291
    Thanks for posting the link, I took the time to see everything on his site. Magnificent work and it's all in the family. He will be at the SCI Convention in Reno, NV this month.
    http://www.showsci.com/
    Was wobbling on going or not, decision made. I'm going.
    The cutter turns while being pulled through the barrel. The barrel only rotates to index for the next groove.
    Oct 2005
    Washington State
    141
    6
    Default Great link!
    Thanks for the link. Awesome rifles.
