Glass Bedding A Stock
Results 1 to 12 of 12
    Jan 2007
    Illinois
    52
    5
    Default Glass Bedding A Stock
    Help me to understand the purpose of glass bedding a stock.
    What affect does glass bedding the stock make if the barrel is floated in the stock? If the barrel does not touch the stock, why does it mater whether the receiver moves in the stock or not?
    Feb 2001
    Arizona
    2,145
    289
    If the receiver is not firmly held by the stock, what guarantees the barrel is not touching the stock?
    It is to keep everything the same from shot to shot. Uniformity of rifle is believed (and seems to be verified) to lead to uniformity of shot fall.
  3. Likes UncleFrank liked this post
    Nov 2015
    Oklahoma
    205
    46
    89
    Glass bedding also maintains uniformity since recoil could compress just wood over time and "loosen" the fit of the action.
    Jan 2007
    Illinois
    52
    5
    There is enough clearance between the barrel and the stock so that the barrel can not touch the stock no matter what the receiver does. The receiver is held very securely in the stock, just not bedded. My problem is accuracy of course.
    Would bedding the stock be the first thing to try after having tried different loads without success?
    Feb 2001
    Arizona
    2,145
    289
    I would bed it, but I bed virtually everything as soon as I get it.
    Dec 2017
    Idaho
    145
    31
    33
    Depends on how bad accuracy is. If 2+” groups at 100, optics are my first stop. I recut crown, polish and lighten trigger.
    Regarding bedding, I use devcon to form both a skim bed and pillars in non magnums and use metal pillars and skim bed for magnums.
    What scope power? Front rest or bipod? Concrete bench or ground? Is the bolt handle touching the stock?
    Nov 2018
    Maryland
    Bedding also ensures that there is no stress on the action from an uneven fit where the body of the receiver is making contact with the stock. If the contact points are uneven, a twist will be imparted to the receiver when the action bolts are tightened.
  9. #8
    Jun 2011
    Bethel, CT
    59
    22
    9
    Stocks, especially wooden stocks, change with atmospheric conditions and from shot to shot. That change allows for differences in harmonic resonance. Barrels always have harmonic resonance; it's actually really amazing to see how much a barrel flexes in a high-speed camera video.
    The best way to deal with harmonics devised so far, is to let the barrel go free with the action secured firmly, so it whips around the same way each time it fires. Those subtle differences from changes in how the rifle is held in the stock dampen or exagerate the harmonics, causing change from shot to shot.
    Try both bedding it and polishing the crown.
  10. #9
    Dec 2008
    Vt USA
    6,669
    656
    2076
    I recently "bedded" the action of an SKS into a Timbersmith stock.
    Metal filled epoxy.
    A small amount filled and bedded at the receiver rear contact, the trigger group clamp up, and the barrel joint. A SMALL amount. Just enough to give uniform contact. call it a square inch at each of the rear points and 2 square inches at the barrel to receiver junction.
    I took it out Monday. Groups at both 50 and 100 yards are notably better.
    Peeps off a front bag. Wooden bench at the range. YMMV! But I'm pleased with the results.
    The SKS does NOT allow a floating barrel without extra-ordinary modification, and as this is a first year, less than a million production number, I'm not going there.
  11. #10
    Jan 2007
    Illinois
    52
    5
    This action sets in a composite stock with more than enough clearance between the barrel and the stock. There is no interference between the bolt and the stock.
    The rifle is fired from wooden bench using a Lead Sled and a remote trigger.
    The scopes used were a Zeiss Conquest HD5 and a Leupold VX3, both set in Tally rings.
    Would putting upward pressure on the barrel at the end of the fore stock be a "trial fix" (easier than bedding) before going to all the trouble of bedding the action?
    More thoughts!
  12. #11
    Dec 2017
    Idaho
    145
    31
    33
    I haven’t had much luck with lead sleds. What caliber? Have you had a buddy shoot it?
  13. #12
    Feb 2003
    Russellville, AR 72802
    467
    7
    25
    Quote Originally Posted by AJA View Post
    More thoughts!
    If the bedding is not good, no other changes will give consistent results. IOW, if the bedding is bad, accuracy will not be consistant-groups are apt to be all over the place.
