GTR BTS Flushing System
Results 1 to 20 of 20
    Nov 2018
    ALAND ISLANDS
    10
    Default GTR BTS Flushing System
    Good day
    Do any of you know thd GTR BTS flushing system? I see PTG has ig on their website and was interested to hear how it works.
    Regards
    Konrad
    Sent from my SM-G960F using Tapatalk
    Dec 2012
    St. Louis, MO
    306
    20
    66
    I checked out the PTG link. Doesn't look like you get much for your $150. Looks very similar to my home-made system. I used a carbonator pump ($50 on ebay), and a Deublin rotary union ($25 ebay) and then just some tubing and a bucket from Lowes. I modified my pump with a lighter spring to give about 20 psi (v. the 150 psi it put out as it was) and that was about it. I use Houghton HOCUT 795MP-RHS water based coolant.
    Dec 2017
    Idaho
    369
    104
    84
    Where did you get that fine, precision machined, green cutting fluid redirection device???
    Dec 2012
    St. Louis, MO
    306
    20
    66
    My own custom design. I'll sell you one for $100.
  5. Likes MetalCarnage, MIBill, TeachMePlease liked this post
    Nov 2018
    ALAND ISLANDS
    10
    Quote Originally Posted by GenePoole View Post
    Thank you for the info and photos.
    Nov 2018
    ALAND ISLANDS
    10
    Good day.
    So i made a rotary coupler using some stainless steel, a bearing and an oil seal. It works great and lo leaks.
    Here is a photo.
    For now i use some tubing and hose clamps to connect to the coupler.
    Regards
    Konrad
    Nov 2018
    ALAND ISLANDS
    10
    Here is some more pics.
  9. #8
    Sep 2015
    Florida
    594
    85
    Have it, works fine.
    Why buy through PTG? Just buy direct from Greg...
    Model BTS | gretanrifles
  10. #9
    Jan 2009
    Georgia
    71
    7
    8
    I switched from a Gre-Tan to a generic Deublin rotary coupler. I drill/tap the muzzle end of the blank for 1/4" NPT. Much better flow, more secure, and it puts the sacrificial first inch of the muzzle to use. If I need to set a barrel back, I have cutoffs with the pipe thread remaining that are threaded to screw on 1/2-28 or 5/8-24 muzzles.
  11. Likes Danny1788, Doug W liked this post
  12. #10
    Sep 2018
    51
    20
    Seems a lot of unnecessary work....
    Sent from my Pixel 2 using Tapatalk
  13. Likes Dieseldoc liked this post
  14. #11
    Oct 2013
    Central Coast, CA
    25
    6
    Quote Originally Posted by jasonixo View Post
    This is also how I do it as well. works great and never leaks and can spin 1200rpm with no hose clamp wobbling all over the place.
  15. Likes jasonixo liked this post
  16. #12
    Sep 2015
    Florida
    594
    85
    Quote Originally Posted by Danny1788 View Post
    You running a carbide reamer? Never heard of running HSS at that high a speed.
  17. #13
    Sep 2018
    51
    20
    How fast are you feeding that in? You need to have a reasonable chip thickness to keep the reamer from chattering.
  18. #14
    Nov 2006
    Greenwood, Ca
    947
    47
    308
    Quote Originally Posted by tobnpr View Post
    I doubt he’s chambering at that speed, but on shorter barrels, I have my flush system hooked up start to finish. I clamp the RPMs at 4500 but I have tested my flush to 6000 RPM and could get away with it just fine.
  19. #15
    Sep 2003
    Pacific NW
    718
    6
    75
    He said he can run the coupler to 1200 rpm w/o wobble.
    Didn't say he chambered at 1200 rpm.
  20. #16
    Oct 2013
    Central Coast, CA
    25
    6
    I don't chamber at 1200rpm, normally around 220rpm. But I have hooked up the muzzle flush system being taped and centered it doesn't wobble or give me any vibration when turning the tenon at 1000rpm and threading at 360rpm. Also I cut the small chamfer on the chamber with a carbide boring bar and spin it at 1000rpm with the muzzle coupler still hooked up.
    heres the one I used and its super cheap, I use a brass 1/4 by 1/8 NPT bushing to thread into the barrel. SS 9SS04MP25XFP25-Z- - Super Swivel - 1/4" Male Pipe X 1/4" Female Pipe - 90 Deg | eBay
  21. #17
    Nov 2018
    ALAND ISLANDS
    10
    Quote Originally Posted by Konrad308 View Post
    This one i made cost me $6 to make and maybe an hour om my lathe. It works great. I have not used it faster than 300rpm. I chamber between 40 and 50rpm so dont really see a need for anything better. The rubber tube is a bit floppy but works and is quick to install. Sometimes when you rechamber there is no extra barrel length to sacrifice so the tube comes in handy there.
    A big thank you to everyone for the comments and photos. Much appreciated.
    Regards
    Konrad
  22. #18
    Mar 2006
    New Jersey
    1,088
    13
    297
    I have seen some setups that use an airline quick connect as a swivel fitting.
  23. #19
    Oct 2013
    Central Coast, CA
    25
    6
    I tried the airline swivel and it worked for a little bit but eventually started to leak, its not really meant to be spun like that and the seals wore out quick.
  24. #20
    Dec 2008
    Vt USA
    6,765
    738
    2318
    Dual Head Air Chuck Washer | Milton Industries
