H&G Sprue Plate Holes
Results 1 to 7 of 7
    May 2006
    Longview,TX
    1,010
    6
    5
    Default H&G Sprue Plate Holes
    I am going to make a copy of a H&G sprue plate and trying to figure out how the deep sprue holes were made.
    Any suggestions?
    Feb 2001
    Arizona
    2,128
    282
    Not familiar with H&G but I think Lymans were of a depth that gave about a .125" hole into the cavity. That size seems to be a compromise between easier sprue cutting and time to fill the cavity. I think you will have to do the math based on the angle of your countersink.
    Dec 2012
    AUSTRALIA
    862
    234
    Its going to depend on bullet diameter too..........but if the holes are too large ,the sprues are hard to cut if using a hard alloy.You can cut with the metal still soft ,but I find that generally causes a metal smear to build up,which can halt the operation until its removed .
    Apr 2008
    West Coast
    280
    56
    48
    The "Cast Bullets" publication put out a few years back by the NRA, by E.H. Harrison, has tons of information on sprue plates, their use, peculiarities, materials,dimensions,etc. Most likely out of print, but you can find them on ebay and such. A bit pricey these days, but worth getting a copy.
    Feb 2001
    Arizona
    2,128
    282
    I probably have that book. I will take a look although I am in the process of moving and may have a hard time finding it.
    May 2006
    Longview,TX
    1,010
    6
    5
    The hole is shaped like a a sharpened pencil
    Dec 2003
    Calgary, Alberta, Canada
    1,401
    89
    the sprue plate is thicker on H&G's, aprox. .250.
