Noooope, not a gun from "back to the future" but a toy-gun. Airsoft gun to be precise.
Please correct me if my terms are wrong. My knowledge of real guns is limited.
First things first, its a "shotgun" using replica-shells that trigger when the firing-cap is pressed. The cap is actually a flat button about 6-8mm wide. Its quite hard to press so you need lever-action to push it, springloaded hammer would simply complicate the system and is not needed.
Shop-image if the replica-shells:
http://www.airsoftonlineshop.com/im...oft_Acc_shotgun_CO2_shells_PPS_SS_12GA_03.jpg
Then theres the fun part. THREE barrels and ONE trigger will have to fire each of the three barrels in sequence. Trigger will be lifted between shots and at that point should cycle to fire the next barrel.
The dept/distance of the push doenst need to be longer than 5-6mm. The push-resistance is a bit heavy but you dont need to push it button very deep to trigger the shell.
It would be best if each trigger-pull simply cycles each, lets call em "hammer rods" when trigger is pushed. Only springs are return-springs for the rods and the trigger itself.
The three barrels will be mounted in allmost side-by-side with one pair being a bit loose from each other. So the trigger mechanism could be a "rotary" shape.
Most likely much of the components will be 3D printed, that means plastic. Take that into considoration.
The gun will NOT be subjected to ANY recoil or pressure. The trigger-pull will be the only force, and the largest the gun will be subjected to.
So, did that make any sense? If not, dont worry, happens quite often with me. Ask and i shall translate.
EDIT:
Found a nifty shooter. A 357 COP derringer. Has a unique rotating trigger-system.
https://www.youtube.com/watch?v=BYTjLLI1Ors
I need something like that. But not "striking" hammer, instead, just a push.
EDIT:
