How to run barrel in steady rest without marring the bluing? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21
    Sep 2010
    moscow,ohio
    6,364
    649
    2116
    it occurs to me that easy and effective would be to buy a cheap er40 MT collet chuck.
    Cut the MT tang off, bore it through...buy a oversize ER collet(~1 3/16") or just a standard er collet if you don't ever work on larger OD barrels.
    Snap collet in er nut and screw it on the chuck, leave it there for a dedicated set up.
    Cut rings whatever plastic to slip over barrel with the OD to the nominal size of collet..clamp down er nut and run the BODY of the er chuck in a standard steady.
  2. #22
    Aug 2003
    New York
    137
    10
    37
    UHMW sleeve on barrel, 3/16" +/- wall. Run rest on that.
  3. Likes MonCeret Gunsmit liked this post
  4. #23
    Jan 2008
    Mountains of Washington State, USA
    434
    136
  5. Likes Butch Lambert liked this post
  6. #24
    Oct 2002
    Poetry Texas USA
    1,874
    476
    265
    Quote Originally Posted by SilveradoHauler View Post
    Unfortunately all will not understand.
  7. #25
    Aug 2015
    Illinois
    1,506
    1117
    651
    Is that a pillow block with a spider in it?
  8. Likes Butch Lambert liked this post
  9. #26
    Feb 2003
    Arkansas
    478
    7
    28
    Quote Originally Posted by MonCeret Gunsmit View Post
    "Cat head"....is that just another name for what we call a "Spider" 'round here or is it a completely different critter?
    Cathead is a tube with a spider at each end.
  10. Likes MonCeret Gunsmit liked this post
  11. #27
    Jan 2008
    434
    136
    Pillow block housing with bearing removed. Then bored out for installation of a ball bearing unit on each side. Machined spindle inside the bearings. Works like a 4 jaw chuck.
    Made it many years for barrel work, I have posted details here on PM in the past. Note the copper wrap around the barrel. Does not marr bluing.
