Indicating pre-drilled hole at 12 O'clock in mill vise.
Results 1 to 14 of 14
    Nov 2020
    5
    Default Indicating pre-drilled hole at 12 O'clock in mill vise.
    Hello,
    I have a gunsmithing project we are working on right now and I can't figure something out. I have a round part (barrel) with no flat on it and it has a single drilled and tapped screw hole at lets say 12 o'clock. I need to drill another hole inline with it six inches away. How would I go about setting that up in a mill vise so that the original already existing drilled and tapped hole is at 12 o'clock in the vise? I need both holes to be aligned as close as possible in a linear fashion to one another.
    Chuck.
    Nov 2008
    Rock Island Wa USA
    55
    98
    9
    put a long screw in existing hole and indicate it vertical
  3. Likes sfriedberg, mhajicek, awander liked this post
    Jun 2008
    Bellingham, WA
    4,324
    1048
    2403
    Put a machinist’s button in the hole. Put the barrel in the trammed vise on a wide parallel. Using your edge finder, find the center of the barrel. Now adjust rotation of the barrel so that the button is centered.
    Screw and screw threads are not very reliable. Long screws, less so.
    Denis
    Mar 2006
    New Jersey
    1,166
    15
    368
    Make a tight fitting screw for the existing hole. Screw it into the hole and then grab it in a drill chuck, or collet, with the barrel held loosely in the vise. Adjust the table till the vise is able to be tightened without moving the barrel. Doing it this way keeps the hole in the 12'oclock position and there is only one axis on the table to be adjusted for alignment.
  6. Likes Scottl, mhajicek, Joe Miranda liked this post
  7. #5
    Nov 2020
    5
    Thank you everyone! I really appreciate the help!
  8. #6
    Aug 2005
    Tucson AZ
    6,620
    10466
    3162
    Well , I'm going to be the asshole and ask why these weren't done in one set up. I will assume it is not your fault and you are cleaning up someone else's mess. This requires a premium charge and an understanding that not all will survive.
    You charge a premium because:
    You usually don't want this kind of clean up work,
    You know that there will be complaints, re: quality, price, time, you name it, They will rarely be pleased
    You should have had the job from day one to do it correctly
    You could have been making money while asking this question.
  9. Likes kendog liked this post
  10. #7
    Apr 2008
    West Coast
    307
    61
    56
    Quote Originally Posted by tdmidget View Post
    Man after my own heart.
    Jobs like this almost always start with "all ya gotta do is..."
    OP one way is to put a gauge pin in the hole and another in the collet/chuck/whatever. Align them for vertical by eye (be surprised how close one can get this way), shim barrel as needed for taper/features, etc., and lock the barrel in the vise. Then locate a pin to the existing hole with your table.
  11. #8
    May 2009
    montana,usa
    62
    42
    How much taper is in your barrel? Will your vise compensate for it? If not, that may be another consideration. And on that same thought, make sure you take your centering touch off at the location of the new hole because unless you have your vise jaw indicated to 1/2 the taper of the barrel you cannot just run back and forth in the X axis and stay over the center of the barrel. Hope that makes sense.
    Dennis
  12. Likes michiganbuck liked this post
  13. #9
    Jun 2012
    Michigan
    12,718
    4326
    4554
    Might make a bushing plate that is a hole (or two) in a bar that can bump the existing first screw and locate the second.
    just a scrap source bar, perhaps with a v on the backside, having two holes 6" apart.
    The V on the backside would keep holes dead straight.
    Might make the hole the size of a center drill.
    Might make it longer so you can use it for other jobs that need spaced holes.
    A slip of masking tape would keep it from making the barrel finish.
    Might use the part for a template.
    Good to have a center punch the same diameter as your center drill so punching is also possible,.
    a flat bushing jig like this can jo-block off and existing location to make next hole .002 or so close.
  14. #10
    May 2017
    Minnesota
    1,490
    1935
    983
    Hazarding a guess, the first hole was probably made years ago, perhaps by the original manufacturer, while the need for the new hole is based on a change in requirements.
  15. #11
    Jan 2008
    Mountains of Washington State, USA
    442
    140
    Best way to drill and tap a barrel is with the barrel installed in the receiver. Then use the receiver flats as a reference.
    Example: A barreled action in my vertical milling machine with a 54 inch long table. Note this is a M700 Rem and I am using the bottom of the recoil lug as the reference. Caution: The barrel and lug must be installed correctly!! This is an aftermarket lug, I throw the stock Rem lugs in the trash. There is a parallel under the recoil lug.
    I made this jig for aligning sights. To the bottom of the receiver of course. Bottom of the jig is machined flat so I can clamp it to the milling machine table.
    All mating surfaces are machined. The bottom flat on the receiver clamps to the block, built in alignment.
  16. #12
    Nov 2020
    5
    Quote Originally Posted by kendog View Post
    Well I am not a gunsmith, I'm not doing this for money, and it's on my gun. If I was doing this for money, I wouldn't have taken the job without knowing how to complete it.
  17. #13
    Apr 2008
    West Coast
    307
    61
    56
    Quote Originally Posted by cdhthethird View Post
    Not taking a shot at you, just agreeing with midget, kinda off topic.
    There are a bunch of different ways to skin this cat, and there are a lot of good suggestions here.
  18. #14
    Apr 2008
    West Coast
    307
    61
    56
    Another way would be to take a weaver style or picatinny base and screw it to your existing hole and sweep the top of it with an indicator. Grand Slam steel bases are flat on top. If you dont have the base with the exact radius on hand you could order one off the chart below, or use one with a lesser radius so the sides of the base form a kind of V block. Still have to shim the barrel for taper, and account for the base not being in alignment with the longitudinal axis of a tapered part, but it will get you good on the Y axis. I use paper shims on 3 sides 1/2 the difference of the taper over the width of vise jaws. In my case 6". Not flashy, but this will get you well within industry tolerance for scope mounting, etc.
