hepburnman
- Feb 20, 2013
- NJ
I would like to know if there is a commercially available HSS or carbide-tipped lathe tool that has a 90 degree point that is good for cutting chamfers on O.D.s or I.D.s? The tools I see are 80 degrees which will cut just a 40 degree chamfer when using the cross-slide. The point should also be well re-leaved for cutting the chamfer on the I.D. without rubbing.
