1yesca
Stainless
- Jun 1, 2004
well it only took 12 years but its done . like most things it started off with an idea and a drawing . some of what is in the
sketch is in the final build and some is not the main things are the two firing pin tips so it strikes the case 180 d apart from
each other and the other is the bolt face being inside the [recess ] bolt so that i could use the two locking lugs . the other
thing of note is the bolt is retracted fully to the rear [against the bolt stop ] it is a single shot and there is no extractor . after
firing the spent shell is extracted with the nail of your index finger [Steve in your case use another finger ] i took it to the
range monday for its first time out and fired aprox. 100 rounds with out a mishap and after setting the scope was hitting clay
birds at 100 yards [on the ground of course] so not to bad for a 22 rim fire short std. vols. ammo of unknown origin . the rec.
was from a k98sniper [all i got was the rec.] that was trashed it had a big dovetail cut in the ring and you could see the
threads and the clip guide had been cut down and the barrel was from a win mod 1885 single shot that had lots of extra
holes in it i would have love to have made it in 22 LR but it started off as a 22 short with a 1 in 22 twist so that's that .
now the two cross bolts in the stock are not for the shoulder crushing recoil of this monster the stock like most of the parts
from this build was a hand me down from an 09 arg that someone at the range gave me after they blew it up. so like they say parts are
parts
parts
