Jerald MI.
Hot Rolled
- Oct 21, 2003
- Clio MI.,USA
I previously installed a spacer to install a device to eliminate cross firing on a M12-16 ga, for a guy. I used the front bead thd'd hole to bolt the device down and attached thru'the spacer to the device at the rear, then attached it all using RTV. There was no rib; plain bb'l.
The customer wants the whole assembly lowered by 1/2 to .055 high. The assembly was tight to the thd'd hole but not attached from there back.
My question; Is there any harm in drilling/taping a hole 3" in back of the frt. bead and adding a 4-40 screw, as long as the threads are flush with the bore is sealed?
I ask because this guy had a mid bead installed in another gun and the 'smith drilled thru' the bb'l into the bore. The customer demanded and received a new bb'l from the 'smith (not me!).
I believe that to have been needless as the screw did not extend into the bore and was sealed to allow no gas to escape.
Thanks, Jerald
Thanks, Jerald
