machining a 1911 slide and frame from bar stock - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21
    Jan 2012
    Savannah, Georgia, USA
    1,672
    2625
    637
    Thank you spyderedge.
  2. #22
    Sep 2010
    South Of Lake Superior, USA
    148
    19
    Quote Originally Posted by lowCountryCamo View Post
    Yes the hood slot or breech face is 0degree24" which amounts to .024 stack @ 5" sine bar. The lugs are 0,52" with a .074" stack. The firing pin bore is same angle as the hood slot.
    Not so, I'm afraid. Only the firing pin bore is 0°24' from the rails. The breech face is 89°8' from the rails (or 0°52' from the "vertical") as shown above the ejection port in View S on Sheet 2 of the Ordnance blueprint.
    Regards
  3. #23
    Aug 2012
    Fort Bragg, Ca
    505
    14
    38
    I am in the process of machining a 1911 slide from 4140 ph and will be doing a 7075 t6 frame next. If anyone wants to follow along I have a thread on the homegunsmith forum in the 1911 section. If there is any interest I could update here too. I have been working on it couple hrs per night for 3 weeks. Thanks for looking. Attachment 98221Attachment 98222Attachment 98223Attachment 98224
    Maybe a link to the thread? It costs $10 to join the forum and its a big forum, takes a long time to find the thread. I havent found it yet
    I'm specifically interested in how you cut the barrel engagement lug slots in the top of the frame? I too am going to try and build a 1911 from stock in 7075. I figure it's strong enough, It's very inexpensive and its more easily worked than steel. I have to wait till payday to order the bar stock and the wait is killing me.
  4. #24
    Jun 2006
    Colo Spgs CO
    106
    13
    14
    Default Which feature is this in the photo?
    Quote Originally Posted by Spyderedge View Post
    ... I like the corner angles over a roundover.
    Thanks....
  5. #25
    May 2020
    INDIA
    will you give me the link for your work in the homegunsmith forum?
  6. #26
    Nov 2007
    MI
    51
    WOW!
    A fine looker.
