Machining a barrel thread adapter
Results 1 to 13 of 13
    Aug 2012
    Canada
    129
    74
    16
    Default Machining a barrel thread adapter
    I want to machine an adapter that screws onto a metric m14 barrel that has M15x0.75 pitch external threads, to convert to 5/8 for more standard muzzle brakes. Concentricity and alignment are going to be critical. Here is my tentative plan:
    1. Drill and tap for the M15x0.75 and screw adapter onto barrel;
    2. insert a range rod into the barrel through the adapter and true the barrel up with spiders at each end just like chambering through the headstock;
    3. cut and thread the 5/8 tenon with it all aligned;
    4. install the muzzle brake and check for alignment with the range rod, correct by truing up the hole through the brake if necessary.
    Does this sound like an effective way to do this?
  2. Likes Butch Lambert liked this post
  3. #2
    Sep 2015
    Florida
    507
    63
    Quote Originally Posted by Grizzlypeg View Post
    You lost me out of the gate. If the barrel is threaded M14 (like an AK, or SKS) where is the M15 coming into the equation?
    Is this what you're looking for?
    M14x1 RH to 5/8-24 RH Thread Adapter
    Reamers follow the existing hole in the brake. When I retrofit, I never bother dialing in precisely because I don't believe a few tenths- or even a thou or two- makes any difference at all. I put the brake in my Buck 6 jaw and ream it to size with a floating reamer holder. A quality brake will have it's hole perfectly concentric to the threads and I'm perfectly content to allow the reamer to follow the hole.
    If it's a new barrel, and it's been dialed in to cut the crown, then I'll bore the brake in-place after threading the muzzle without disturbing the setup.
    Sep 2010
    moscow,ohio
    5,561
    540
    1755
    bet he has a Norinco M14...
  5. Likes Grizzlypeg liked this post
  6. #4
    Aug 2012
    Canada
    129
    74
    16
    Yes, it is a Norinco M14 with metric thread. The barrel is threaded M15x0.75 for the flash suppressor nut. That thread can also be used to attach a muzzle brake. I want to make an adapter that screws over the (M15x0.75)threaded end of the barrel and terminates in 5/8-24. I'm just mulling over how best to machine it accurately for alignment with the bore. I'm thinking it should be done similar to setup for reaming a chamber, in that I need the external threads I generate on the adapter to be accurate to the bore, just like the shank on a barrel.
  7. #5
    Feb 2001
    Arizona
    2,171
    296
    Have you done the math for this? M15 is nominally .590" and 5/8 is .625". that gives you .035"/2 = .0175" thickness in which to cut the 24 TPI threads. Looks like the minor diameter of 5-8-24 is .574-.575". I don't think a sleeve will work; the threads would have to be one in front of the other.
  8. #6
    Aug 2012
    Canada
    129
    74
    16
    Yes, definitely the threads cannot be on top of each other. Wish I had an easy way to post up a drawing. I envisage a section that goes over the barrel, and a 5/8 threaded portion forward of the barrel.
  9. #7
    Sep 2010
    moscow,ohio
    5,561
    540
    1755
    Have you considered *trying* a .595"-32 brake??? It's so close it may be a non issue?
  10. #8
    Oct 2010
    Dewees Texas
    2,164
    26
    562
    I used to make blank muzzle breaks. One of the sizes we made was 1/2-28. If you bought one of these you should be able to bore it out and thread it .590-32, which is pretty close if you do not have metric threading gears.
  11. #9
    Mar 2019
    ALAND ISLANDS
    14
    5
    If you’re testing a bunch of 5/8 brakes or other muzzle devices then why not. But if it’s a dedicated brake I think FredC has the right approach.
  12. #10
    Aug 2012
    Canada
    129
    74
    16
    Makes sense about the one off vs trying various brakes. I am mostly doing this for the fun of it, and would like to do it the more complicated way of making an adapter. I can buy a brake that just screws on, but its more fun to do something myself and learn in the process. I have ordered a tap in M15x0.75, and the external 5/8 thread I can cut on my lathe.
  13. Likes gbflyer liked this post
  14. #11
    Sep 2015
    Florida
    507
    63
    Well...if ya want the practice, sure.
    But for $35....
    M15x1 RH to 5/8-24 RH Thread Adapter
    For best appearance, buy a round 5/8" brake with an OD slightly larger than the OD of your adapter, screw it on, and turn the OD to "blend" with the adapter. It'll look like one piece when it's done.
    Will that barrel with the front sight fit through your headstock? Gonna be a bitch with that entire barreled action swinging around behind your outboard spider.
  15. #12
    Aug 2012
    Canada
    129
    74
    16
    Quote Originally Posted by tobnpr View Post
    But for $35....
    Too bad its the wrong thread. The M14S from Norinco uses M15 x .75 threads.
    I can remove the barrel for the job, and the front sights are on the flash suppressor that will have to come off to be replaced with the brake.
    I would like the practice. Making stuff is part of the hobby. It would be far cheaper for me to get someone else to chamber my barrels than me buying a lathe, all those measuring tools, tooling for the lathe, reamers, etc. But, for me, its what I want to do with my spare time.
    I like your idea of blending the adapter and brake. That will make it look pro.
  16. #13
    Sep 2015
    Florida
    507
    63
    Post up some pics as you progress. Interesting project...good luck with it!
