machining bore in AR upper receiver
Page 1 of 3 123 LastLast
Results 1 to 20 of 46
    Sep 2018
    763
    1417
    361
    Default machining bore in AR upper receiver
    hey guys, i'm about to start programming a run of upper receivers. what would you guys recommend for the main bore on these? gonna be on a VF3 with trunion. no TSC unfortunately.
    Sep 2008
    N W Washington
    59
    12
    9
    A lot depends what you intend to use them for, For long range competition a tight one inch, maybe a half thou under one inch, to the other extent if they are to be used on top of class 3 lowers (M16's) a little loose would be more reliable, maybe 1.002. I kinda like them when it takes just a little heat for the barrel to fit in, although some barrel extensions are made a whisker oversize for this reason. The tighter the better for accuracy but a little looser for a blaster, just my opinion I'm sure others have different ideas, Jon P.
  3. Likes empwoer liked this post
    Sep 2018
    763
    1417
    361
    Quote Originally Posted by JonP View Post
    these are gonna be 9mm uppers built for USPSA competitions. my question is like what kinda tools should i use? drill+ream?
    Feb 2001
    Arizona
    2,252
    365
    I think you should use a boring head and boring bar. That will give you the best control over location. Drilling/reaming location will be worse.
    Although I see you plan to use a CNC mill. In that case, I would rough drill the hole and then mill the hole to desired dimension. That should give you good control over location. If milling doesn't give you the desired diametral precision, you could mill undersize and ream.
    Sep 2018
    763
    1417
    361
    Quote Originally Posted by GGaskill View Post
    are you aware this is a 1" bore 8" deep?
    Jul 2011
    Brusly, LA
    830
    21
    345
    From what I understand the best uppers are drilled, bored undersize, reamed, then honed to final size.
    FWIW, make the bore true 1" not over, not under. reason is that barrel extension to bore fit is critical for accuracy and function. If you are worried about to tight a fit of the bolt carrier in the bore, its pretty easy to polish the humps on the bcg that they ride on in the bore, but Ive never ever seen a bcg that's too tight cause problems.
    What I have seen is a barrel extension that was too sloppy a fit in the oversized upper to give good accuracy without putting a shim in it or using an oversize extension.
  8. Likes empwoer liked this post
  9. #7
    Sep 2018
    763
    1417
    361
    Quote Originally Posted by akajun View Post
    Good to know, thanks for the advice!
  10. #8
    Jan 2015
    Missouri
    1,261
    221
    790
    Kennametal makes a drill for that has replaceable tip I use a carbide tipped reamer. Do you have thru spindle coolant ? It takes a tall z to drill that. I mount right to table and I use up all of a 20 inch z no 4th axis. I’m not sure you can do it with 20” and a trunion
    Thanx Don
  11. #9
    Sep 2018
    763
    1417
    361
    Quote Originally Posted by D Nelson View Post
    Thanx Don
    no TSC unfortunately i believe our VF3 is the extended Z. believe it should fit.
    never mind, just checked, VF3's have 25" of Z standard.
  12. #10
    Jan 2015
    Missouri
    1,261
    221
    790
    I made fixtures for each op. If you don’t have thru coolant I think you will have to peck the shit out of it. But the ream does leave a nice finish. The worst part of the deal is the hole for the bolt cover. That is a long way down to it
  13. Likes empwoer liked this post
  14. #11
    Sep 2018
    763
    1417
    361
    ya, gonna peck for sure. we're looking into a better machine in the near future, that one will have TSC for sure.
    which hole are you talking about? not sure i'm picturing it right.
  15. #12
    Jan 2015
    Missouri
    1,261
    221
    790
    The small hole that holds the bolt cover on
  16. Likes empwoer liked this post
  17. #13
    Jan 2015
    Missouri
    1,261
    221
    790
    Also you will need a self centering vise for them
  18. #14
    Sep 2018
    763
    1417
    361
    AR9's dont use those so no biggie.
    i use a kurt 420D 5 axis centering vise.
  19. #15
    Jan 2015
    Missouri
    1,261
    221
    790
    The ones I build have them
  20. #16
    Jan 2015
    Missouri
    1,261
    221
    790
    here is one I built
  21. Likes empwoer, MetalCarnage liked this post
  22. #17
    Sep 2018
    763
    1417
    361
    here is one I built
    wtf, why would you need a forward assist with a PCC?
    that just looks like a standard AR15 upper on an AR9, the uppers i'll be making are simplified, no forward assist, no ejector cover and the ejector port is much smaller.
  23. #18
    Sep 2008
    N W Washington
    59
    12
    9
    Empwoer that sounds like a fun project, yea I think drill, ream and hone if you can, I assume you are making from billet, do you use the side charging handle ? Yea no forward assist no brass deflector and no cover makes it simple and functional for competition. A snug 1 inch bore will give a lot less carrier tilt witch really helps, although there are other ways to minimize bolt carrier tilt. It is really amazing the range of tolerance in different carriers etc.I think if I was making some uppers from scratch I would drill ream and hone to size as I got the carriers. There is no argument though that the barrel extension fit is the most important, although carry rarely is it loose. Good luck. Jon P
  24. #19
    Feb 2013
    Idaho
    780
    182
    902
    The big boys drill and then bore with a custom boring head. The head is just below nominal diameter with two opposing cutters. One roughs, the other finishes. They make the hole in seconds and hold tenth tolerances. Not cheap, but if you wanna play with big dogs, you gotta pee in the tall grass.
  25. Likes empwoer liked this post
  26. #20
    Jan 2015
    Missouri
    1,261
    221
    790
    Gw Schultz makes all the tooling for the Ar uppers there is a bunch of custom cutters for the uppers. They also need to be broached if you use a standard charging handle
