machining bore in AR upper receiver - Page 2
Results 21 to 40 of 46
  1. #21
    Sep 2018
    333
    447
    127
    Quote Originally Posted by JonP View Post
    Empwoer that sounds like a fun project, yea I think drill, ream and hone if you can, I assume you are making from billet, do you use the side charging handle ? Yea no forward assist no brass deflector and no cover makes it simple and functional for competition. A snug 1 inch bore will give a lot less carrier tilt witch really helps, although there are other ways to minimize bolt carrier tilt. It is really amazing the range of tolerance in different carriers etc.I think if I was making some uppers from scratch I would drill ream and hone to size as I got the carriers. There is no argument though that the barrel extension fit is the most important, although carry rarely is it loose. Good luck. Jon P
    should be! i'm making lowers already right now for a company, that was a very challenging but rewarding experience, looking forward to doing the uppers. yes, they're from billet, no side charging (forward assist) and no ejector port cover, these uppers are pretty simple.
    what kind of hone would i use on something like this?
  2. #22
    Sep 2018
    333
    447
    127
    Quote Originally Posted by D Nelson View Post
    Gw Schultz makes all the tooling for the Ar uppers there is a bunch of custom cutters for the uppers. They also need to be broached if you use a standard charging handle
    i'm not sure why you'd need to broach them. i assume you're talking about the channel the charge handle rides in? that can be machined with a 3/8" .125" thick slot mill with 1/4" shank
  3. #23
    Jan 2015
    Missouri
    1,020
    210
    619
    Oh yeah you going to mill thru the rear take down boss
  4. #24
    Jan 2015
    Missouri
    1,020
    210
    619
    The uppers get broached believe it or not
  5. Likes empwoer liked this post
  6. #25
    Sep 2018
    333
    447
    127
    you're right, i see what you're saying now. fuck. didnt even notice that before.
  7. #26
    Jan 2015
    Missouri
    1,020
    210
    619
    I’m trying to tell you I have made a few of them if you will listen I can tell you a lot about making them and all the ways that try’s to get you screwed up
  8. Likes empwoer liked this post
  9. #27
    Sep 2018
    333
    447
    127
    sorry i didnt mean to come off as a know it all, i do appreciate any and all help i can get!
    how would i go about broaching them? save that for the last step? in the middle of the process? can you recommend anyone to do the broaching?
  10. #28
    Jan 2015
    Missouri
    1,020
    210
    619
    If you use forgings they vary in thickness as much as .012 you either need a self centering vise at about 2500.00 or probe every upper before marching or separate all forgings by thickness and change your programs. It throws off the bore to one side. You need to machine the top rail first thing there is special cutters for that also. Then you need to hold the uppers by the rail at all stations if possible for it is the only true feature. The top of the receiver where the barrel hits needs to be cut in the same op as the bore. You need a long special drill to put the gas tube hole in. A broach to cut the charging handle slot.if you are putting the gas door on there is special cutters for the long drill bit the long slot mill for the side cut. There is more but I use 4 machines and takes about 15 minutes to make one upper. Hopefully this helps you out some
    Don
  11. #29
    Sep 2018
    333
    447
    127
    Don
    not a forging, making these out of billet.
    no gas port on these, no door either. do you do the broaching yourself?
  12. #30
    Jan 2015
    Missouri
    1,020
    210
    619
    Do it in the mill with a m19 spindle lock and stroke the z with spindle off
  13. #31
    Jan 2015
    Missouri
    1,020
    210
    619
    Done in the same op as the gas port hole the cut out for the charging handle side cuts
  14. #32
    Sep 2018
    333
    447
    127
    my plan was to do it in 2 ops originally. first op cut the picatinny (found the tools for those), bore and everything else i can get to on the setup in a 5 axis, then flip it over, hold the upper by the top rail and finish the bottom side. i'm guessing i'll have to write a custom cycle to broach this.
  15. #33
    Jan 2015
    Missouri
    1,020
    210
    619
    Are you using a forward assist if so there is a step drill for that also you have to lay it over at the right angle. Also the rear take down hole isn’t round it is oval. The worst problem they have beat the price down so low on the uppers the forging is 13 dollars 3 dollars for anodizing and they sell for 30 bucks
  16. #34
    Jan 2015
    Missouri
    1,020
    210
    619
    The best idea is like a new frontier side charger they get big dollars for them over 200 so there is some cushion I don’t think you will find anyone honing a ar 15 upper there isn’t enough money in it. Now ar10 still brings some money
    Don
  17. #35
    Sep 2018
    333
    447
    127
    no forward assist.
    thankfully these are for competition rifles so customer is willing to pay reasonable money for them.
  18. #36
    Jan 2015
    Missouri
    1,020
    210
    619
    That helps
  19. Likes empwoer liked this post
  20. #37
    Jan 2015
    Missouri
    1,020
    210
    619
    That helps
    i have been getting 200.00 for a set of Ar10 matched sets bare Si defense
  21. Likes empwoer, TeachMePlease liked this post
  22. #38
    Sep 2018
    333
    447
    127
    these are the lowers i'm making now and a model of the uppers i'm starting on.
  23. #39
    Feb 2019
    Massachusetts
    24
    7
    Quote Originally Posted by empwoer View Post
    i dont know how you guys make money on this stuff ?
    Tac sol 9mm upper are $90 or so.
    Those Di sets , looks nice seen them as high as $500 and $325 ish .
  24. #40
    Feb 2019
    Massachusetts
    24
    7
    Are you DI or sub contractor.
    $200 is pretty darn good price.
