omrc7771
Hot Rolled
- Mar 3, 2013
- Oshkosh, Wis. [email protected]
Have read thru most threads and need advice on the simplest method to convert to a swing safety.
The simplest way would be to email me. I have 6-8 in stock, blued and ready to ship.
[email protected]
Or,, you can buy the Wisner or Chapman two position swing safety kit from Brownells or else where and alter the military shroud if you have a milling machine. You'll need the proper tooling. The fixture to hold the shrouds was pretty easy to make. I've used several of the Dakota 3 position safties. I use my rotory table witha 3 jaw chuck mounted on it and just "run by the numbers" to locate the bolt lock detent for the proper fit. I've seen some installed with just a 'guess' at where that detent cut goes that were pretty sloppy. Ya, they locked the bolt, but you could raise the handle a third of the way. Amature work, to say the least.
I don't think it's the engineering of the locking pin, Jim. That detent cut location is critical, though. With the system/method I use the bolt handle hardly moves at all when the safety & bolt locking is engaged (usually less than your typical model 70 does). I set-up my rotory table w/chuck Sunday afternoon and did 3 Mauser bolts, all with the same excellent results. I will admit, I like Eds' safeties better and I do like Wisners' kit much better than Chapmans'. Haven't experience with Gentrys' 3 position safety/shroud. If I was only going to do one or two safeties, I'd just buy what I needed from you and call it good. Be hard to justify the cost of the tooling & fixturing, otherwise.Therin lies the problem with the Gentry and Dakota three position ones; the position of the locking pin on those is not engineered correctly and will allow the bolt handle to lift. If you want a three position one, go with the Ed Lapore or Satterlee units. My conversion of the 98 shroud does not require a bolt mod but the cocking piece sometime will need an adjustment. Do not buy the CHapman unit; go with the Wisner. The geometry on Wisner's lever is MUCH better and is the only one I will use.
Jim
Let us know how the "drop in" works.
Notice
