Model of 1905 vs M1905 bayo grip screw
Results 1 to 16 of 16
    Jan 2021
    Alabama
    7
    Default Model of 1905 vs M1905 bayo grip screw
    I’m trying to replace a grip screw on an early model of 1905 bayonet (1909 dated SA). I bought a catch lever assembly for the later models (1942+), and quickly discovered that the it is too large to thread into the escutcheon.
    The screw that came out of the bayo has a shaft dia of .1515”. At the end of threads (at shaft), it measures .1505”. It appears to taper to .1470” at the thread start, but that could be due to oxidation, use, and age. The bayo has been blued (came in the bright from the factory), so it has been reworked at some point. If I understand correctly, likely before 1917 (most were parkerized when returned to the arsenal).
    The later model screw measures .1585” at the shaft and .1550” at the thread OD.
    At 32 tpi, it’s a coarse thread, but seems to fall between a #6 and a #8.
    Can anyone shed light on this? I’m finding it incredibly difficult to find a replacement grip screw for early versions.
    Thanks in advance.
    Apr 2011
    Nebraska
    1,386
    2271
    458
    I can't shed any light on this but why not just make the replacements? Do you have a lathe?
    -Ron
    Jan 2021
    Alabama
    7
    Quote Originally Posted by MetalCarnage View Post
    -Ron
    I don’t...
    Jun 2004
    393
    247
    37
    if you have brophys book on the Springfield rifle i believe it may have that info in there
    Feb 2001
    Arizona
    2,275
    373
    Sounds like a #7 screw. They did things like that in days of yore.
    Jan 2021
    Alabama
    7
    Quote Originally Posted by 1yesca View Post
    I’ll look for this book. I’ve been reading Gary Cunningham’s Bayo Points. Lots of good info I haven’t yet found anywhere else. But no mention of the screw.
    Jan 2021
    Alabama
    7
    Quote Originally Posted by GGaskill View Post
    I wondered if there was such a thing. The measurements seem to fall nicely between #6 and #8. Interestingly, the grip screws from later variants of the bayo are slightly larger. Minimal, but enough that they are not backwards compatible.
    Apr 2011
    Nebraska
    1,386
    2271
    458
    The only reference I have close to look at is "Manufacture of the Model 1903 Service Rifle" so take this for what it's worth.
    The screw shown in this book is straight, 0.1525" diameter and 33 threads per inch.
    -Ron
    Jan 2021
    Alabama
    7
    -Ron
    I could see 33 tpi. It’s just to the plus side of 8 threads on a .25” piece.
    In the reference you have, is it called out as a specific thread, or does it just give the dimensionals?
    Apr 2011
    Nebraska
    1,386
    2271
    458
    It may be in the text of the book some where but I have been unable to find it. I found heat treating, materials, etc. but no "thread form". Here is the drawing they give with the associated text:
    Hope this still helps,
    -Ron
  11. Likes 1yesca liked this post
  12. #11
    Aug 2005
    Tucson AZ
    6,665
    10619
    3200
    -Ron
    That won't help. It's all about bayonets, not bayos.
  13. #12
    Jul 2011
    Americus, Georgia
    458
    561
    136
    Are you wanting a duplicate or a useable bolt and nut?
  14. #13
    Mar 2019
    Wisconsin
    344
    33
    174
    Probably not relevant but if the replacement parts you sourced are current production it's possible they may be some type metric fastener spec.
  15. #14
    Apr 2011
    Nebraska
    1,386
    2271
    458
    Quote Originally Posted by standardparts View Post
    I don't think that they were using metric fasteners here in the U.S. back in 1909, especially for military ordnance. Unlikely to be "current production" as well but I have been wrong before.
    -Ron
  16. #15
    Feb 2001
    Arizona
    2,275
    373
    You could probably make a #7-32 screw from mild steel and let the threads distort as they are screwed in. Can't imagine that wouldn't be sufficient. None of my lathes cut 33 TPI.
  17. #16
    Apr 2011
    Nebraska
    1,386
    2271
    458
    I just looked around a bit and found what you are looking for from Numrich -
    M1 Garand Bayonet Parts, Scabbards | Numrich Gun Parts
    They are repo but contain the nut and washer so everything should fit, at least with itself. At under $12 it would be hard to beat.
    I don't understand why they would have used a 33 count thread anyway when the logical (maybe that was the problem) choice would have been a 32?
    FWIW
    -Ron
